Introduction: Building a Laser Cut Birdhouse
You know what a birdhouse is, I don't need to explain it. However, not apparent to most, a lot of birds are homeless, sleeping on the street, living out of old iPhone boxes discarded by wannabe hipsters, having to scrounge together to even afford breadcrumbs. I propose a change, I propose we build birdhouses!
The approach in this instructable is to use a laser cutter to make most of the individual pieces for the birdhouse, and assemble it with glue and a few pieces of hardware, you may know them as screws and hinges.
Material:
Wood, if you don't want to go through the process of flattening, planing and gluing together boards you could just as well use plywood.
Glue
Screws
Hinges
Threadlock
Tools:
A variety of woodworking tools, a bandsaw, jointer and planer would be very handy, as well as a large disc sander
Laser cutter, if you don't own one you may be able to get access at a local Techshop or similar
Sandpaper
Screwdriver
Good luck in your birdhouse building, remember to keep the final area down, so you don't need to apply for planning permission!
Thanks for watching, subscribe either here (or at YouTube for more videos) if you like what you've seen and want more!
Cheers!
