Introduction: Building a Mandrel for Coiling Wire. (Chainmail)
This is my first instructable, and I've decided to document me building a Mandrel. This project took me roughly an hour to build while taking pictures. It's a little different than other Mandrels I've seen on this site, so I figured it would give people more options.
Step 1: Materials and Tools
Materials
- 32 inch 5/8" Metal Dowel
- 32 inch 3/8" Metal Dowel - This determines the inner diameter of your rings
- (6) 2 1/2" Screws
- 4ft piece of 1x5
Tools
- Power Drill
- 5/64" Drill Bit
- 3/8" Drill Bit
- 5/8" Drill Bit
- Screwdriver Bit
- Saw
- Measuring Device
Step 2: Finding the Right Holes.
Next, mark the locations of your holes on the 1ft sections. My first hole I marked was for the larger 5/8" dowel. I marked that in the center of the wood and roughly 6 inches from the bottm. I say roughly because my tape measure is missing and I really just eyeballed the hole. This hole is placed high enough that when the spool of wire is on the dowel, the spool will be clear of the bottom of the Mandrel.
The next hole to mark is the hole for the 3/8" dowel. I marked that about an inch diagonally from one of the top corners.
Next, mark the pilot holes on the bottom of the 2ft section of wood to attach the other two pieces. I did this by placing the pieces about 1 inch in from the edge and marking 3 holes in a strait line. The reason I placed them in from the edge was so I did not risk spliting the edge of the wood with use.
Step 3: Drill That Wood!
Now stuff finally starts happening.
Start by placing your two 1ft sections on top of each other, lined up, and drill the 3/8" and 5/8" holes through both pieces of wood at the same time. This will help them line up later; you'll also need to do less boring of the holes to make the rods fit smoothly.
Next, drill pilot holes through the bottom of the 2ft sections using a 5/64 inch bit. Don't forget to drill the pilot holes into the bottom of the 1ft sections too, or you'll increase the chance of spliting those when you put the screws in!
Step 4: Screw It!
Now you've got something that's starting to look good. Only one more step to go!
Step 5: Stick Your Rod in It!
You're done!
Step 6: Work It!
Then, attach the end of the wire to the smaller rod with a tiny little vice grip.
After that, attach your drill that you used for the project to the end of the 3/8" rod.
Slowly power the drill while guiding the wire into a nice and neat coil with your hand. I highly suggest you wear leather gloves becaue galvanized wire rubs off on your hand, and it starts to heat up too.
Warning!
Always wear safety glasses and gloves when using this. The coiled wire can build up tension and snap back. Eyes are VERY hard to replace! Trust me, I'm a Paramedic.
