Introduction: Building a Modbus Client With XIAO ESP32C3 to Read Holding Registers of Modbus TCP/IP Devices
Modbus is a widely used communication protocol in industrial automation for interfacing various electronic devices. In this tutorial, we will explore how to create a Modbus client using the XIAO ESP32C3 microcontroller to read holding registers of Modbus TCP/IP devices. The XIAO ESP32C3, equipped with Wi-Fi connectivity, allows us to establish communication with Modbus TCP/IP devices over a network.
- XIAO ESP32C3 microcontroller board
- A Modbus TCP/IP device (e.g., PLC, sensor, or any other Modbus-enabled device or Simulator)
- Arduino IDE installed on your computer
- Basic understanding of Modbus protocol
Step 1: Install Modbus Library
To communicate with Modbus devices, we need to install the Modbus library. Follow these steps to install the library:
- Open the Arduino IDE and navigate to Sketch > Include Library > Manage Libraries.
- Search for "modbus-esp8266" and install the "modbus-esp8266" library.
Step 2: Writing the Code
Now, let's write the code to create a Modbus client using the XIAO ESP32C3. Below is a sample code snippet to read holding registers from a Modbus TCP/IP device:
#include <WiFi.h>
#include <ModbusIP_ESP8266.h>
const char* ssid = "YourWiFiSSID";
const char* password = "YourWiFiPassword";
IPAddress remote(192, 168, 1, 7); // Address of Modbus Slave device
const int START_REG = 0; // Starting holding register
const int NUM_REGS = 10; // Number of holding registers to read
const int INTERVAL = 5000; // Interval between reads (in milliseconds)
WiFiClient client;
ModbusIP mb;
uint16_t res[NUM_REGS];
uint8_t show = NUM_REGS; // Counter for displaying values
uint32_t LastModbusRequest = 0; // Variable to track the last Modbus request time
void setup() {
Serial.begin(115200);
// Connect to WiFi
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// Initialize Modbus client
mb.client();
void loop() {
if (millis() - LastModbusRequest >= INTERVAL) {
LastModbusRequest = millis();
if (mb.isConnected(remote)) {
// Read holding registers from Modbus Slave
uint8_t transaction = mb.readHreg(remote, START_REG, res, 10, nullptr, 1);
// Wait for the transaction to complete
while(mb.isTransaction(transaction)) {
mb.task();
delay(10);
// Print holding register values
Serial.println("Holding Register Values:");
for (int i = 0; i < NUM_REGS; i++) {
Serial.print("Register ");
Serial.print(i);
Serial.print(": ");
Serial.println(res[i]);
} else {
// If not connected, try to connect
mb.connect(remote);
Replace "YourWiFiSSID" and "YourWiFiPassword" with your Wi-Fi credentials. Also, set the serverIP variable to the IP address of your Modbus TCP/IP device.
Step 3: Upload the Code
Step 4: Testing
Once the code is uploaded successfully, open the Serial Monitor in Arduino IDE. You should see the XIAO ESP32C3 connecting to your Wi-Fi network and then attempting to read holding registers from the Modbus TCP/IP device. If everything is set up correctly, you should see the data received from the Modbus device in the Serial Monitor.
Step 5: Conclusion
In this tutorial, we've learned how to create a Modbus client using the XIAO ESP32C3 microcontroller to read holding registers from Modbus TCP/IP devices. With this knowledge, you can now build your own Modbus-enabled IoT applications and integrate them into industrial automation systems. Experiment with different Modbus functions and parameters to explore more functionalities offered by the Modbus protocol.
