Introduction: Building a Wood Planter for LEVdisplay
This is a custom project for LEVdisplay magnetic levitation device. Alternative levitation displays can be used, but the dimensions will vary.
LEVdisplay is available on our website, or Amazon Prime.
Use coupon code INSTRUCTABLE for 20% off at levdisplay.com.
Free shipping included
Step 1: LEVdisplay Hardware
LEVdisplay is for makers who want to build their own levitation projects.
The levitating magnetic disc can hold up to 13 ounces (approximately 350 grams) in mid-air
30mm maximum levitation distance
The base color is dark brown
Step 2: Planter Materials
Each section of the planter is cut form Midwest Products 9MM craft plywood, except for the flat 3MM piece near the bottom.
Step 3: Planter Dimensions
Each of the six sections is 65MM X 65MM
Step 4: Bottom Piece for Disk Magnet
The bottom piece of the planter can be cut from three separate pieces of 3MM ply, or milled from a single piece of 9MM ply with the help of a CNC router.
Step 5: Cutting
Cut out the 6 pieces with a jig saw, router, or cnc machine.
Step 6: Sanding and Wood Glue
Sand each piece using 100 grit sandpaper and glue together with Titebond Veneer Glue.
Step 7: More Sanding
Once all of the pieces are glued together, give it one more sanding with 150 grit sandpaper
Step 8: Finish
Apply two to three coats of Shellac Wood finish.
Step 9: Plants
Air plants are recommended since they don't require soil and little water
Step 10: Levitate!
Levitating Plants!
