Introduction: Bullet Effects on Scale Models
Hi guys!
And Girls!
And... others :D
Today I'm going to explain you how to make very easy and cool bullet effects on your scale model ;)
On the picture: Stug III ausf G by Tamiya - 1/35 scale
Step 1: Materials
You are going to use very poor materials, let's see what:
1 - Scale model (of course)
2 - Exacto knife with a bit tip (See images for references)
3 - Matt Gun Metal (Any brand will do the trick)
Step 2: !Safety Hazard!
You will work with a sharp knife that will automatically hurt your fingers so BE CAREFUL, use protections and enjoy this Instructable ;)
Step 3: Quick Physics Lesson
You are going to add some machinegun and other low caliber shots on your vehicle therefore be careful to what I'm saying:
Because of the thick armour of tanks (and other armored vehicles) a normal bullet WON'T penetrate the chassis, so don't force through your exacto knife because this will create a non realistic hit.
Take few minutes and visit the fantastic world of "The Internet" to check how thicker is the real armour of your vehicle, you won't regret that ;)
Another important thing: if you are going to place your model in a diorama just check were enemies are: if their minifigures are on the ground you will do some bullet hits at a man-height. Otherwise, if enemies are placed on the top of a building you will need to add bullet hits on the top of your vehicle.
So remember: check and compare the minifigures height with your model.
Step 4: The Trick
Now let's work!
After studying your model and your diorama it's time to get in action:
1 - Choose a place where hit your model and start gently to push and rotate.
2 - After marking a little bit, start to press and rotate harder (not too much, you won't pierce side by side): Now you have your bullet hit!
3 - Now dip your exacto knife's bit in the metallic grey and plant the coloured bit where you have done your bullet hit.
4 - Check if it's how you like it. If not, quickly take a piece of wet cotton and rub it on the model, this will erase the color.
Pro tip:
Check on the Internet for realistic bullet hits on armoured vehicle and try to replicate them ;)
Step 5: Done!
If you like your work, let it dry for a few hours!
Just for your delight check out other types of bullet hits on my model ;)
If you liked this instructables, please feel free to comment, I will be glad to answer you as fast as possible ;)
Auf Wiedersehen,
MattJKF
