Introduction: Glue Stick Lamp
hi!, this time I will share a tutorial on burning beautiful glue sticks using arduino, glue, cardboard, tape, and acrylic pipes.
Step 1: Get to Know Arduino
You may wonder, what is Arduino? Arduino is an electronic platform based on open source that allows users to change the programming code.
Step 2: What You Need
215/5000
In this meeting, we need:
1x Arduino
1x LED (recommended to use red LEDs)
1x a to b USB
1x liquid glue
1x acrylic pipe
For carton pieces:
2x carton size 6x5 cm
2x carton size 2x6 cm
1x carton size of 5x2 cm
Step 3: Making the Case
glue all the cartons you have until it becomes a boxed one with one end open.
Step 4: Schematic
arrange a series of electronics (arduino and led) like the picture provided (the bent led is an anode).
Step 5: Coding
Upload the code to Arduino as below:
const int PIN_LED = 5; // PWM pin
void setup () {
pinMode (PIN_LED, OUTPUT); }
void loop () {
int value Random = random (176);
analogWrite (PIN_LED, 60+ Random values);
delay (200);
Step 6: Make a Pipe Rod
this pipe section is one of the important things, follow the instructions below!
1. Glue the pipe using glue (like the picture in the beginning)
2. stick the led on the bottom of the pipe
Step 7: Tidying the Circuit
make a hole in the cardboard (the size of a pipe hole) then put the end of the pipe that has a led and glued. Also insert arduino into the carton box.
Step 8: Finished
Plug the USB cable into the Arduino USB hole and plug the other side into the USB computer hole.
