Introduction: Chained Endless Falls Paracord Bracelet
Here is how you can learn to make a Chained Endless Falls Paracord Bracelet. Good Luck!
B.T.W - This is my first instructable I've ever made, so please feel free to share this, or comment if you have any pointers, or if you like what you see! Thank You Mrs. Kavli! <- My Senior Art Teacher!
Step 1: Instructional Video
Step 2: Materials Required . . .
You are going to need a pair of scissors, 55 inches of para cord (color of your choice), 83 inches of para cord (color of your choice), and finally a lighter.
Step 3: Cow Hitch Loop (Beginning of Bracelet)
Find the center of each cord (the long cord and the short cord).
Step 4: Twist the Short Cord As Exampled in the Photo.
Step 5: Part II of Starting the Cow Hitch Loop . . .
In the first photo put the longer cord into the shorter as exampled in the photo, and than pulled the longer cord behind the shorter cord as in the second photo. In the third photo, push the longer cord through the loop below. (Photos tell you which cord is which.)
Step 6: Finishing the Cow Hitch Loop . . .
Starting from the last photo, pull the longer cord up and tight, and than adjust the short cord to 1 cm for the loop end.
Step 7: Starting the "Endless Falls Variation"
Once you tighten the knot, you are going to want to fold the short cord behind the long cord as in photo #2, and do the same for the other side as in photo #3.
Step 8: Continuing the "Endless Falls Variation" . . .
From the last slide you are going to put the longer cord through the middle loop as in photo #1, and than pull it all the way through as in photo # 2, 3, 4, and do the exact same thing on the other long cord as in photo # 5, 6, 7.
Step 9: Continuing the Cord . . .
Once done pulling the long cords through the loop, you are than going to want to tighten the entire bracelet so it does not come loose.
Step 10: Finishing the "Endless Falls Variation" . . .
Once you have your desired length for your bracelet, you will start to finish the bracelet. You will need to kinda repeat the beginning. First loop the left short cord behind the long cord and loop the right short cord also behind. Than grab the right short cord and push that through the right side, and do the same for the left side, as you can see in the photos.
Step 11: Cutting Off the Extra Bits . . .
As you can see in the photos, you are just going to cut off both ends of the short cord as close as you can to the bracelet. Use your lighter to singe off the fluffy string pieces, also so the bracelet doesn't come apart.
Step 12: Toggle Button Knot Finish!
Take the 2 long cords, and loop them as in the photos, and go ahead and tighten them good, and cut and singe the ends like the last time.
Step 13: Your Done, Great Job!
Finished Product!
