Introduction: Butterfly Fairy Bed
Hello fellow instuctablers. I am going to show you how i made a bed for my daughter.
it all started when she was about 3 and getting closer to needing a "big girls bed." I didn't like any of the ones i had seen in the stores so i thought what better thing than to make a butterfly and/or fairy bed.
Step 1: The Design
so first step is the design process. grab out the ol' graph paper and pencil and sketch up a few ideas.
the main shape i came up with was a butterfly and then incorporated the fairies in the wings for the bed head. For the bed end was a side view of a butterfly with some floral influences.
Step 2: Gathering Materials and Tools
As i am a Boilermaker by trade i naturally went with steel for the bed.
material list-
25x25x1.6mm painted SHS
20x20x1.6mm painted SHS
50x25x1.6mm painted SHS
12mm round bar
10mm round bar
8mm round bar
6mm round bar
50x4mm mesh
75x6mm flat bar
As far as quantities go i can't quite remember.
Tools-
MIG welder
grinder (with cutting discs, grinding disc, flat disc)
hammer
scraper/chisel
pipe bender
tape measure and ruler
permanent marker
scriber
lots of clamps
rope
theres probably some more but i can't remember right now.
Step 3: Getting Started on Making It
The first thing i did was get a big piece of ply board bigger than the size of the bed head and drew the bed design on it so i could use that as a template.
once that was done i used the rope to follow a line on the template and the measured it. this was the length i had to cut the steel, but i ended up cutting each piece about 50mm longer just to be safe.
After cutting the piece of steel to length it was time to form the shape. i used a pipe bender because that's all i had. It was a long and tedious process as each curve was a lot of tiny little bends. But i got there in the end.
i repeated this process for all parts of the bed that were made out of the SHS.
once i had a few of the parts formed i laid them out on the template and marked the angles i had to cut then tacked them together.
Step 4: Getting More Progress Done
after the main shape of the bed was all welded and cleaned up it was time to start on the fairies.
i used 8mm round bar for the body and wings. i made quite a few little jigs to get the bends right for each little piece. I also used the vice quite a bit.
the same process was used here as in the last step. used the rope to follow the line on the template, measure, add a bit and cut. but i used the vice and jigs Instead of using the pipe bender.
Step 5: The Bed End
this was my favourite part to make. all the processes were the same as the other end, just different shape.
Step 6: The Mattress Frame
once both ends were completed it was time to make the frame that holds the mattress. i didn't like the idea of having the wood slats so i decided to use mesh instead.
i used 20x20x1.6mm to make a frame the same size as the mattress for the mesh to sit on. Then i used 50x25x1.6mm welded to both sides for added strength to stop the frame from sagging.
Step 7: The Test Fit
Now that the 3 main parts are all done it was time to fit it all together to make sure that its going to bolt up with no troubles.
i did have to make a couple little adjustments to the bolt holes with a die grinder. But apart from that it was all good to be sent off to get powder coated.
Step 8: Final Assembly and to Make the Bed.
i decided to go with getting it powder coated white so that it would fit in with other furniture easier than a pink or purple bed would.
The day i got it back from the powder coaters i assembled it and surprised my daughter with it.
this bed was done over about 18 months in my spare time.
i hope you enjoyed this instructable!
vote for this in the metal contest
