Introduction: CAD a D4
About: Thingiverse: https://www.thingiverse.com/theengr42 GitHub: https://github.com/TheENGR
The goal of this instructable is to CAD a D4 with only 1 parameter
Link to my object
CAD Software, I use OnShape as it is free
Step 1: Base Triangle
  1. Make an equilateral triangle whose center is on the origin
  2. Add your one dimension to say how big the triangle is
  3. Add a construction line from the constrained point down along the "Right" plane
  4. Make the construction line be equal (same length as) the side of the triangle
Step 2: Find the Top
  1. Make a construction circle whose radius is the length of the side of triangle
  2. Draw a construction line up from the origin to the circle
Step 3: Loft the Triangle
  1. Loft the base triangle to both the top point found
Step 4: Finish!
You now have a "blank" D4!
Feel free to add numbers to it or whatever else you want!
