Introduction: CAMEO - a Goose Eggshell Decorated With Paper Clay
This is an original Faberge-style goose egg design using molded paper clay for the main decoration.
A fun and rewarding art form which is very fiddly and exacting as fine measurements and details matter. A great craft to learn patience.
- 1 x evenly oval-shaped, cleaned, and dry medium to large goose eggshell
- 1 egg marker or paper tape for measuring
- Oval template (optional)
- pencil & rubber for marking
- 1 x Dremel tool or an air drill for cutting the shell
- a piece of fine sandpaper
- Leukopor or paper tape 2.5mm
- narrow paper strips (for the 'slings')
- fine gap filler
- a clear drying glue
- epoxy glue
- 1 pack air dry paper clay - I used Creative Clay
- silicone molds for the cameo and beads as shown
- silicone rose leaf and petal veiner molds (optional)
- acrylic paints - white and lavender (or your own color choice)
- pearl paint for the top coat
- fine paint brushes
- hair dryer
- Mod Podge - Matte
- Mod Podge - Gloss
- fine white pearlized glitter
- 1 round wooden base for the egg to stand on
- 1 x gold plated goose egg stand
- 3 x gold plated narrow filigrees for the side rose mounts
- 1 x gold plated round slightly domed filigree for the finial top
- 1 x large round filigree to cover the base top
- 2 meters of narrow white braid
- 1/2 meter of fine gold cord
- 1 small pair of sharp scissors
- 1 small metal spatula or palette knife
- lace draper tool for positioning
- long tweezers
Step 1: Preparing, Measuring & Cutting the Eggshell
For this first stage, you will need the following:
- Oval template
- Mod Podge - matte
- Paint the eggshell with several thin coats of Mod Podge matte to strengthen the shell
- Use the hairdryer on low heat in between coats to speed up this process
- Lightly sand when completely dry
- Measure the widest part of the egg
- Divide this measurement into 3 to mark the placement of the ovals
- Place the egg in the egg marker and draw lines at equal distances from the top and the base
- Use an oval template, the egg marker or hand draw the 3 ovals (the size of the bead mold) with equal space in between each oval
- Continue to draw up the guidelines as shown (sorry, mine is a bit messy)
- Carefully cut out the 3 ovals using a 6mm curved diamond blade in the Dremmel or air tool
- Using the pencil, number each oval and the shell so you know where it was cut from
Step 2: Creating the Oval 'slings'
For this second stage, you will need the following:
- lace draper
- long tweezers
- To support the reversed ovals, create a 'sling' using strips of narrow paper. Cut vertical and horizontal strips as shown and secure them with small pieces of paper tape by going through one of the other ovals. Repeat with the second oval
- The 3rd oval is more challenging. Cut and make the sling
- Carefully insert it into the oval pressing the ends onto the shell using the foot on the lace draper and using long tweezers and the lace draper, place inside the securing pieces
- There should be enough slack that the oval will rest on the tape 'sling' and meet at the edges
- Adjust the slings where needed so that the oval sits close to the cut edge - another very fiddly part
Step 3: Sealing in the Reversed Ovals
For this third stage, you will need the following:
- fine gap filler
- Take the cut oval piece and place it onto the 'sling' of the corresponding number
- Use the fine gap filler in the gap around the oval as shown
- Smooth it out with the spatula or finger as you go until it is filled
- Allow the filler to dry thoroughly
- Lightly sand if needed to smooth out any rough spots
Step 4: Painting the Egg Shell
For this fourth stage, you will need the following:
- hair dryer
- Mod Podge - Matte
- Mod Podge - Gloss
- Using the pencil, finish drawing up your design for the paint lines
- Using the lavender color, paint the oval and an even measure around the rim as shown
- Make sure the paint is thinned with water so as not to leave brush marks
- Do several coats, drying thoroughly in between coats, and when fully dry, lightly sand
- Paint the wooden base with the lavender color
- Brush over the lavender color on the eggshell and base with Mod Podge Matte to seal
- Next paint the white areas. When fully dry brush with Mod Podge Gloss
- Quickly sprinkle over the wet area with the pearl glitter, and gently tap off the excess
- When dry, coat the glittered areas with Mod Podge Gloss
Step 5: Creating the Paper Clay Embellishments
For this fifth stage, you will need the following:
- silicone rose leaf and petal veiner molds - optional
- Fill the cameo and bead molds with the paper clay, making 3 of each.
- Using the paper clay, make 3 small roses to go onto the side filigrees and the larger rose with 3 rose leaves for the finial top.
- Paper clay is easy to mold so keep the roses simple and petite
- When dry, trim and seal all pieces with Mod Podge Gloss
- Paint 2 thin coats of acrylic pearl paint on the pearl oval, cameos, and roses plus leaves
Step 6: Applying the Braid & Paper Clay Moldings
For this sixth stage, you will need the following:
- 2 meters of narrow picot braid - white
- a clear drying glue for braids
- paper clay pearl rings, cameos, and roses
- lace draper tool
- 1 painted round wooden base
- Glue the cameo in the center of each oval followed by the pearl oval
- Use the lace draper to move them carefully into place
- Put the glue in a fine line along the white glittered edges. Place the white braid on top and carefully miter the joins with sharp scissors
- Press each join with the foot of the lace draper to make a neat finish
- Trim the base with the braids as shown making your joins invisible
Step 7: Gluing on the Gold Filigrees and Roses
For this seventh stage, you will need the following:
- 3 x dried clay roses
- lace draper tool
- epoxy glue
- Mix the two-part epoxy for a few minutes and glue the filigrees in between each oval making sure they are at the same height
- When thoroughly dry, mix another small amount of epoxy and glue a rose onto the center of each filigree
- I usually glue all the filigrees simultaneously, including the stand onto the base
- You can use pieces of paper tape to secure each glued piece until completely dry
Step 8: Gluing the Finial to the Top & Egg to the Stand
For this final stage, you will need the following:
- 1 x gold plated round slightly domed filigree for the top
- 1 x larger clay rose with leaves
- 1 painted and braided round wooden base
- 1 x gold plated goose egg stand or a stand of your choosing
- epoxy glue
- lace draper tool
- Using epoxy, glue the stand to the painted and decorated base making sure it is centered.
- Now, place the base with stand onto a piece of A4 and at eye level so you can turn it to make sure it is perfectly upright
- When this is dry, place the egg onto the base, noting where it connects
- Add a little epoxy glue to those points and place the eggshell back onto the stand
- Turn it carefully, adjusting where necessary so that the egg will be perfectly straight
- Now the finishing touch. With a toothpick, touch the underside edges of the filigree with epoxy glue and place it onto the center point of the top of the egg. When dry, glue the rose with leaves onto the center of the filigree
- Well done, your egg is finished!
