Introduction: CARD DEALER
This project was made as part of an assigment of "Usos academics en terminologia específica en angles I" in which we where asked to build a small project with an Arduino Uno board.
We decided to build a card dealer for poker games (just for the challenge, we know it's not going to be better than someone actually dealing).
Step 1: What You'll Need
- 1 x Arduino Uno board
- 2 x Stepper motors 28byj-48
- 2 x Stepper motor drivers
- 1 x LCD screen 16x2
- 1 x IIC controller
- A bunch of jumpers (lots of them, you'll never have to many jumpers)
- 3 x 1kohm restistors
- 3 x push buttons
- 1 x welding board
- 1 x tin coil for welding
- 1 x welder
- 1 x wood sheet (420x297mm)
- 1 x PMMA sheet (210x297mm)
- 1 x Glue
- 1 x Pain (red in our case)
- 4 x Bearing (10mm inner diam)
- 4 x Nylon axis (15mm long 10mm diam)
- 1 x Stell axis (20mm long 3mm diam)
- 2 x gears (50 tooth and 10 tooth)
- 1 x rubber band
Step 2: Step 1: Build Your Circuit
Step 3: Step 2: Get Your Code and Test It!
The code is like supper beginer, but im very proud of it since its my first arduino code ever :)
(i'll try and enter more commentaries to it later on)
//Enter Libraries
#include #include #define TOTALSTEPS 32*64 LiquidCrystal lcd(0); //Enter Variables int stepstoDo; int state = 0; //Inital state int stage = 1; int i = 0; boolean playerS = false; boolean e = false; int p = 2; int players = 4; int maxplayers = 8; int minplayers = 2;
int Bdelay = 20; int cardDelay = 2000; //stepper motors pins int motorPin1 = 5; int motorPin2 = 6; int motorPin3 = 7; int motorPin4 = 8; int motorPin5 = 9; int motorPin6 = 10; int motorPin7 = 11; int motorPin8 = 12; //Arduino pin definition int const LEFT = 1; int const ENTER = 3; int const RIGHT = 4; //detector int trigerpin = 13; int echopin = 2; float distance; long t;
void setup() {
//detector
digitalWrite(trigerpin, HIGH);
delay(10);
digitalWrite(trigerpin, LOW);
attachInterrupt(echopin, detector, CHANGE);
// put your setup code here, to run once:
pinMode(LEFT, INPUT);
pinMode(ENTER, INPUT);
pinMode(RIGHT, INPUT);
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("CARD");
lcd.setCursor(0, 1);
lcd.print("MASTER");
delay(3000);
lcd.clear();
lcd.print("WELCOME!");
delay(1500);
lcd.print("press enter");
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(motorPin5, OUTPUT);
pinMode(motorPin6, OUTPUT);
pinMode(motorPin7, OUTPUT);
pinMode(motorPin8, OUTPUT);
Serial.begin(9600);
}void loop() {
if (state == 0 && digitalRead(ENTER) == LOW) {
lcd.clear();
state = 1;
//GAME SELECTION
if (state == 1) {
lcd.print("Select players!");
playerS = true; //PLAYER SELECTION
if (playerS == true) {
if (digitalRead(ENTER) == LOW) {
playerS = false;
state = 2;
delay(Bdelay);
else if (digitalRead(LEFT) == LOW) {
if (players <= minplayers) {
players = maxplayers + 1;
players--;
delay(Bdelay);
else if (digitalRead(RIGHT) == LOW) {
if (players >= maxplayers) {
players = minplayers - 1;
players++;
delay(Bdelay);
lcd.print("PLAYERS = "); //print number players
lcd.print(players); //print number players
//--------------------------------POKER-------------------------------------------
else if (state == 2 && playerS == false) {
if (stage == 1) {
if (e == false) {
lcd.clear();
lcd.print("POKER!!");
lcd.print("dealing...");
e = true;
else if (e == true) { //deal 2 cards each
for (i; i < (2 * players) - 1; i++) {
S_deal();
stepstoDo = TOTALSTEPS / players;
S_tower_H();
delay(Bdelay);
} lcd.setCursor(0, 1);
lcd.print("press ENTER");
if ( digitalRead(ENTER) == LOW) {
stage = 2;
e = false;
i = 0;
delay(Bdelay);
else if (stage == 2) {
if (e == false) {
lcd.clear();
e = true;
for (i ; i < 1; i++) {
S_deal(); //burn
stepstoDo = TOTALSTEPS / 10; //distance between positions
S_tower_H(); //move to position 1
delay(Bdelay);
S_deal(); //deal
S_tower_H(); //move to position 2
delay(Bdelay);
S_deal(); //deal
S_tower_H(); //move to position 3
delay(Bdelay);
S_deal(); //deal
stepstoDo = 3 * TOTALSTEPS / 10;
S_tower_A(); //go back to burn area
delay(Bdelay);
stage = 3;
e = false;
i = 0;
delay(Bdelay); }
//wait
else if (stage == 3) {
if (e == false) {
lcd.clear();
e = true;
for (i; i < 1; i++) {
S_deal(); //burn
stepstoDo = 4 * TOTALSTEPS / 10;
S_tower_H();
delay(Bdelay);
S_deal(); //deal
S_tower_A();
delay(Bdelay);
stage = 4;
e = false;
i = 0;
delay(Bdelay);
//burn 1
//deal 1
//wait
else if (stage == 4) {
if (e == false) {
lcd.clear();
e = true;
S_deal(); //burn
stepstoDo = 5 * TOTALSTEPS / 10;
S_tower_H(); //move to position 5
delay(Bdelay);
S_deal(); //deal
S_tower_A(); //go back to home area
delay(Bdelay);
stage = 5;
e = false;
i = 0;
delay(Bdelay);
else if (stage == 5) {
if (e == false) {
lcd.clear();
lcd.print("END OF GAME");
e = true;
stage = 1;
state = 1;
e = false;
delay(Bdelay);
void S_deal() {
for (int d = 0; d <= TOTALSTEPS / 5; d = d + 4) {
int motorSpeed = 5; //variable to set stepper speed
// 1
digitalWrite(motorPin4, HIGH);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin1, LOW);
delay(motorSpeed);
// // 2
// digitalWrite(motorPin4, HIGH);
// digitalWrite(motorPin3, HIGH);
// digitalWrite(motorPin2, LOW);
// digitalWrite(motorPin1, LOW);
// delay (motorSpeed);
// 3
digitalWrite(motorPin4, LOW);
delay(motorSpeed);
// // 4
// digitalWrite(motorPin4, LOW);
// digitalWrite(motorPin2, HIGH);
// delay(motorSpeed);
// 5
delay(motorSpeed);
// // 6
// digitalWrite(motorPin3, LOW);
// digitalWrite(motorPin1, HIGH);
// 7
delay(motorSpeed);
// // 8
delay(cardDelay);
//declare variables for the motor pins
void S_tower_A() {
for (int t = 0; t <= stepstoDo; t = t + 4) {
// 1
digitalWrite(motorPin5, HIGH);
digitalWrite(motorPin6, LOW);
digitalWrite(motorPin7, LOW);
digitalWrite(motorPin8, LOW);
delay(motorSpeed);
// // 2
// digitalWrite(motorPin5, HIGH);
// digitalWrite(motorPin6, HIGH);
// digitalWrite(motorPin7, LOW);
// digitalWrite(motorPin8, LOW);
// 3
digitalWrite(motorPin5, LOW);
delay(motorSpeed);
// // 4
// digitalWrite(motorPin5, LOW);
// digitalWrite(motorPin7, HIGH);
// 5
delay(motorSpeed);
// // 6
// digitalWrite(motorPin6, LOW);
// digitalWrite(motorPin8, HIGH);
// 7
delay(motorSpeed);
// // 8
//set pins to ULN2003 high in sequence from 4 to 1
//delay "motorSpeed" between each pin setting (to determine speed)
void S_tower_H() {
// 1
delay(motorSpeed);
// // 2
// 3
delay(motorSpeed);
// // 4
// 5
delay(motorSpeed);
// // 6
// 7
delay(motorSpeed);
// // 8
Step 4: Step 3 : Cut Your Wood and Pmma Boart
Use the dwg. file attached.
(if you have acces to a laser cutter then its sooooo much easier)
Step 5: Step 4 : Assembly 1
Step 6: Step 5 : Pain Your Case
Step 7: Step 6 : Assembly 2 (connect Your Circuit and Make It Fit)
Step 8: Step 7 : Final Assembly
Start playing!!
