Introduction: CD Polisher
A nick is just a nick, a scratch is just a scratch
The fundamental things apply
As CD's die
(forgive me Warner Bros)
So you went to the local library & got a DVD movie to watch with your honey. Guess what? It won't play!
That little tramp who returned it yesterday carried it in her purse for three days with no jewel case!
Run it through this CD Polisher for five minutes & it will play like new.
I store my data archives on DVD-RW. If one bit is misread, the whole file is trash. A data disk must be exactly written & verified.
This machine can be used to repair disks that have become unreadable. There is a very good chance that the files can be recovered.
When putting together the parts for this project, use my mantra 'Goodwill, Goodwill'. If you shop well (or have a big stash of parts) the machine will cost under twenty dollars to build.
Before we start, let me apologize for my lack of describing how to accomplish each and every step. I am assuming that a project meister who chooses to build this machine can infer much info from the pictures.
It's my dad's fault. He taught me by doing, not by lecturing.
So, in memory of my father, I will not give a list of tools, materials, or skills needed to complete this project.
Thanks dad
Well, if you see that the machine actually runs, you might get to step 3. Or 4. 5 is a good one, too.
Here's a video of the thing in action:
Step 1: The Bearings
Find a pair of junk rollerblades at Goodwill. For two bucks you will get sixteen bearings, axles, bushings.
At the home center I found 3/4in CPVC (not PVC) fittings. The bearings are a perfect slip fit. The tube stub is cut off & cemented to lock the bearing in the housing.
1/4-20 hardware is used to create the axle. The bushing flange is cut off (shorter than the bearing width) to center the axle.
We need two of these.
Step 2: Turntable
Thrift stores are my first stop when I need material. Floppy disk storage box. Fifty cents. Great source of plastic sheet.
By the way...what's a floppy disk?
While you're there browse the wood things section and get pieces for the rest. Look for shelves, curio cabinets, hat racks.
The center nubbin is a piece of 9/16in OD nylon tubing. Press fit into the platter.
The pad is cut from a rubberized place mat.
Attach the platter to the bearing assembly with #4 wood screws.
Step 3: Alignment
This shows the position of the pad upon the disk.
The buffing pad front edge must cross the disk as close to perpendicular as possible.
Keep this in mind while positioning the disk platter and the buff motor assembly.
Note from author: 20 years ago I fixed a Jimmy Buffet CD that skipped. Instructions at the time said use toothpaste, a damp cloth, and scrub across the disk perpendicular to the tracks. The method has not changed. Any polish lines that are not perpendicular to the track will scatter the light and make the track unreadable. Or I may be full of shit. Further research required.
Step 4: Base
The platter motor is a 5 rpm microwave oven turntable drive. I found a junk oven in my alley.
A short length of tubing on the shaft gives good traction.
(Note from author: If you haven't figured yet, I've got a sh*t-load of parts I've collected just waiting for worthy projects.)
The drive belt is from an upright vacuum cleaner. Use a sharp utility knife to split it into two belts. This is (was) a Hoover 'Y' belt.
Maybe you can buy a 2-pack for your home vacuum, then sacrifice one for the cause.
Mounting locations depend on the belt length and the buffer motor configuration. Make some sketches and figure out approximate positions.
Ponder this step until the buff motor assembly is finished.
Step 5: Buff Wheel
The plastic backing pad is thin (.050in) flexible plastic cut from a Sterilite storage container lid. Diameter is 3 inches. The center hole allows access to screw head for height adjustment.
I drew six quadrants on the buff pad to use as a guide.
The buff material is 1/2in wide felt weatherstrip with adhesive backing.
Use six separate pieces to keep the pad flexible. Cut to fit, peel backing to attach, then trim with scissors.
Step 6: Buff Motor
My motor is from a B&D 12v cordless drill. Goodwill. 2 bucks.
I extended the shaft with a length of brass tubing, staked it, then added a piece of plastic tubing to help grip the belt.
Google your motor part number. My 12v motor is rated for 24v. I run it at 18v with PWM speed control. More power. Higher rpm. Yessss.
Mount the drive belt without stretching, but with solid contact.
Step 7: Buff Motor Assembly
1/8in brass pins mount the buff motor assembly to the base so that it swings freely. Gravity creates the working pressure.
If the drive motor can handle it, add weights for more pressure.
I needed to add a cage to keep the belt centered on the motor shaft. It is made from 1/16in brass rod and pressed into drilled holes.
Step 8: Setup
The pad position?
Passed: Well within Specs.
The back view shows the angle of attack between the pad and the disk. The front of the pad is doing the work. The back of the pad makes no contact.
Move the platter up or down to adjust the angle.
Step 9: Controller (waaaay Optional)
I built this with a PWM speed controller based on the LM324, and a relay to supply AC to the platter motor.
Power comes from a separate 18vdc 5 amp power supply.
You see in the video that the buff motor I use goes damn fast (my guess >12,000 rpm). Better to start at slower speed or else the whole area gets a shower. If you start at full speed, build a shower curtain.
These little motors suck 3+ amps, more at stall. Choose a power source that can handle the current.
Pardon my lacing tape, I've worked in aerospace and can't help myself.
Step 10: Let's Run It
Use plastic polish for polycarbonate (auto headlight lenses). Expensive but it works great.
NFG is techspeak for 'could not find disk'.
Saturate the felt with water, then rub in a small amount of polish.
Run for five or ten (or twenty) minutes. Add polish to the buff pad every few minutes. Keep the disk surface oily.
Result from this run: Couldn't save this one as a data disk. Status went from unreadable to recordable, with errors. Still good for movies or music. (Do not buy cheap disks for archives.)
Note to builder: No operating instructions are available. This is your new toy. Tweak the shaft positions & angles & weights & fluids until you get the results you want. Mine works great, but took a little fine tuning.
And don't tell the librarian you fixed her DVD. She would not understand.
Thanks for looking at my baby
wotboa
52 Comments
3 years ago
Love the cable lacing!
9 years ago on Introduction
The microwave motor also can be used as a taser. :-)
Reply 4 years ago
I know this comment is a bit dated, and off topic - but I am pretty sure you are talking about the Magnatron in the microwave. Those are very highly dangerous to use, and without the proper shielding, it can cause serious injury and/or death.
-Just sayin'....tho not recommended.
On a brighter note, I'm going to make the CD Cleaner machine from this Instructable...I'm a mechanical engineer, and I think drawing something like this in AutoCAD would be fun and very cool to build. THANK YOU FOR SHARING YOUR IDEAS! :+)
~Salvage0ne
6 years ago
try it
8 years ago on Step 10
i remember i had a game disk that had some VERY bad scratches (from around 8 years of being face up on my sisters floor) and i used a cotton ball and toothpaste to fix the disk it took a very long time but those scratches were much better, not gone. using toothpaste to start with (if there are bad scratches) might work well with this system just make sure you clean well when done
9 years ago on Step 5
This is indeed a great idea for retrieving those CDs & DVDs.
I suppose if a fibre optic polishing paper would be of a great help here. I have not got an opportunity to try it on CDs but feel confident it would work on them.
This could be used to rewinding those rental dvds before returning them. no more fees!
huh?? Are you thinking of VHS tapes?. Geez I feel old
its ok im only 16 and i knew tht he was refering to VHS tapes.
rofl
This looks like a great project. Well done. I can think of another use I'd like your opinion on. How about polishing iPhone screens where the gorilla glass has become scratched?
Hiya Brad I.
Corning Gorilla Glass is......glass. (alkali-aluminosilicate)
My machine polishes polycarbonate plastic.
You're on your own, my friend.
seeya
Thanks wotboa!!
Well explained IMHO, in spite of your being so deprecating. And something I need badly as I lost lots of valuable invaluable stuff.
While I have a pwm unit I made for something else, I won't use this. I have instead 2 other ways out. One, a 1 Amp mains transformer with with 3 to 12V taps every 3 Volts. If this has insufficient power for the motor I get hold of, then I have a 12V, 4A mains transformer which I can use with series hi-wattage resistors (I have a boxful!!) to give me a couple of 'acceptable' speeds. Inefficient, sure, but OK for a once-in a-way thing.
Thanks for kicking this lazy bum!!
Erich.
Hi Erich
I like the visual of your kitchen table covered with a half dozen live wires. We've all done that, yes?
Build one of these machines. Post it. Help unlock the mystery of disk repair. The more versions that are built and used, the stronger the solution.
My machine works just fine. Let's see how other builders might do it.
seeya
PS pardon my sarcastic and cynical humor. It may be construed as deprecating.
9 years ago on Step 9
If you decide to do an Instructables on just this step alone, that would be well worth reading! Unless you know of some other useless reference for an aspiring maker to learn more about powering and controlling motors.
Get a Skip Dr.!
http://www.digitalinnovations.com/
The motorized version will polish it/sand it smooth. There's enough layers of plastic there above the data layer to buff it up well and get rid of those scratches that bend the laser and cause the issues. Any filler compound wil do just that - FILL IN the marks. It doesn't clear it up.
The product just works!
I never researched the polishing compound until after I published this project. Should have done it, I guess, but my results are always positive. If it works, etc.
The Meguiars 10 that I use is based on Micro Abrasive Technology. It does cut the disk surface and removes shallow scratches. The finished disk does not have a mirror finish, but my repaired disks seem to show that the polish lines are so fine they do not affect the disk performance. Perhaps the next step would be to use Meguiars 17 to bring the surface up to a mirror finish. Or not.
PS I don't work for Meguiars
I checked out the Skip Dr before I settled on my design. If I had a machine shop, I could make a Skip Dr.
Instructables celebrates the tinkers of the world. I am one. My machine uses no fancy BS. It runs well. It does the job it was designed to do. Any project meister with a work bench and a few hand tools can build one, like I did.
Imagine that.
Please consider this: True hobbyists do not buy something that they can build themselves. Quod erat demonstrandum.
Seeya
Does it rewind it though? I always have trouble rewinding my CDs.
Take your unwound CDs to the local loonie bin.
They will help you.
wotboa
i tried but they said that they didn't have a rewinder either.
