Introduction: CHESS SET FROM POP STICKS
A set of chess pieces made from pop sticks.
MATERIALS :
Approx. 60 Pop Sticks*, or similar thin plywood
Wood glue
Dark coloured wood stain
Clear varnish, eg. Urethane oil
*Pop sticks are small strips of 2 mm thick white wood, 110 mm x 10 mm with rounded ends, commonly used in flavoured ice blocks. They are also sold in craft shops in packs of about 200 for various crafting purposes. 2 mm plywood can be substituted if desired.
Step 1: CONSTRUCTION :
The file Popstix Set.pdf contains patterns for the pieces. These can be printed out and glued to the pop sticks prior to cutting out with a coping saw or Dremel® tool. The paper patterns can then be removed by light sanding. The bases are made from two half-circles, 32 bases are needed in total. Half of the pieces need to be stained with a dark coloured wood stain prior to assembly and gluing as shown in the diagram above.
The assembled pieces were painted with 2 coats of clear urethane oil varnish.
Step 2: OPTIONAL ADDITIONS :
I made a magnetic set by gluing the pieces to dead Lithium call batteries ( CR2032 ) and using a magnetised rubber sheet for the chess board. ( 20 mm diameter steel washers could be substituted for the Lithium cells )
The Kings and Queens were decorated with silver metallised beads.
