Introduction: CNC From Recycled PC Parts
In this instructable I will show you how to make a very low cost CNC from recycled computer parts. This machine can do a lot of stuff depending on what you attach to it.
1. It can be used as a Plotter. (Attach a Pen as tool)
2. It can be a Laser Engraver. (Attach a Laser module as tool).
3. It can be used as a Router. (Attach a Drill Machine as tool).
4. It can be used as a PCB Plotter. (Attach a Permanent Marker as tool).
5. It can be used as a 3D Printer. (Attach extruder and hot end)
6. Possibilities are many.
This CNC is made up of recycled PC parts: old Printer, Scanner and CD/DVD drive.
Step 1: Parts and Tools
1.1 Recycled PC Parts:
- CD/DVD-ROM x 1
- Printer x 1 (Canon S530D)
- Scanner x1 (HP Scanjet 3970)
Hints:
- The older the printer the better.
- The newer the scanners the better.
1.2 Parts I bought:
- Arduino UNO R3 x1
- Arduino CNC Shield V3 x1
- A4988 stepper motor driver x 3
1.3 Tools:
- Soldering Iron and Solder
- Computer with Arduino IDE
Step 2: Get Useful Parts
CD/DVD Drive:
2.1 Get stepper mechanism from a CD/DVD drive
The CD/DVD stepper mechanism will be using as Z-axis here for a Plotter.
Getting the stepper mechanism from a CD/DVD drive has been documented in other instrutables very well already:
https://www.instructables.com/id/Mini-CNC-Foam-Cutter/
Printer:
2.2 Get carriage movement mechanism from a printer.
The printer stepper mechanism will be using as Y-axis.
2.2.1 carriage movement mechanism w/ DC motor
2.2.2 Stepper from paper feeder
Scanner
2.3 Get carriage movement mechanism from a scanner
The scanner stepper mechanism will be using as X-axis.
Step 3: Build X-axis
- The X-axis is the easiest step here. We don’t have to do much about it. Just need to disassemble the scanner and solder wires to the stepper motor.
- Put the metal board from CD/DVD on the carriage of the scanner.
Step 4: Build Y-axis
Remove the gears from paper feed stepper motor, and then put the pulley from the main DC motor on it. To match the size, I am using plastic food wrap, totally works.
Step 5: Build Z-axis
Make a pen holder and attach it to the CD/DVD stepper mechanism.
Step 6: Axis Assembly and Motors to Arduino CNC Shield Wiring
The assembly is very simple, please refer to the pictures.
The wirings are simple too. The point is to use multimeter to determine correct A+ A- / B+ B- for each motor.
For more information about Arduino CNC Shield, please visit http://blog.protoneer.co.nz/arduino-cnc-shield-v3-00-assembly-guide/
Step 7: Compile and Upload GRBL to Arduino
7.1 Download GRBL source code
Download source code (v0.9i) from https://github.com/grbl/grbl/archive/master.zip Once downloaded, unzip it and you'll have a folder called grblmaster
7.2 Compile GRBL source code
7.2.1 Load GRBL to Arduino IDE (Version>1.6.1) as a library
https://www.instructables.com/files/deriv/FZ0/2NHF/ILFI4C0P/FZ02NHFILFI4C0P.LARGE.jpg
https://www.instructables.com/files/deriv/F6T/ZKUU/ILFI4C0R/F6TZKUUILFI4C0R.LARGE.jpg
7.2.2 Open the GrblUpload Arduino example.
Click the File down-down menu, navigate to Examples->Grbl, and select GrblUpload.
https://www.instructables.com/files/deriv/FAT/KSLD/ILFI4C0S/FATKSLDILFI4C0S.LARGE.jpg
7.2.3 Compile and upload Grbl to Arduino
Connect your Arduino Uno to your computer. Make sure your board is set to the Arduino Uno in the Tool->Board menu and the serial port is selected correctly in Tool->Serial Port. Click the Upload, and Grbl should compile and flash to your Arduino!
https://www.instructables.com/files/deriv/FLW/M513/ILFI4CBN/FLWM513ILFI4CBN.LARGE.jpg
Step 8: Settings for GRBL
8.1 X-axis
Stepper motor from HP Scanjet 3970 is 96 steps per revolution, and the timing belt pitch is 2.032mm. A4988 stepper drive is set to 8x micro step resolution. So it takes 96x8=768 steps per revolution now.
768/2.032 = 377.953 steps to make X-axis travel 1mm without gears, but it turns out it's a 1:2 gear ratio, so it takes 377.953 x 2 = 755.906 steps now.
Command $100=755.906 makes the correct X-axis settings for GRBL
8.2 Y-axis
Stepper motor from Canon S530D Printer is 48 steps per revolution, the pulley is 25 teeth, and the timing belt pitch is 1.5 mm. A4988 stepper drive is set to 16x micro step resolution. So it takes 48x16=768 steps per revolution now.
It travels 25x1.5mm=37.5mm per revolution.
768/37.5 = 20.48 steps to make Y-axis travel 1mm
Command $101=20.48 makes the correct Y-axis settings for GRBL
8.3 Z-axis
Stepper motors from DVD drive are 20 steps per revolution, and the screw is 3mm per turn. A4988 stepper drive is set to 8x micro step resolution. So it takes 20x8=160 steps per revolution now.
160/3 = 53.333 steps to make Z-axis travel 1mm
Command $102=53.333 makes the correct Z-axis settings for GRBL
Step 9: Power Supply
A 3-4A 12V laptop power supply works very well.
Step 10: Finish
This is the final result and I hope you like it.
Thanks so much for watching this instructable and enjoy!
