Introduction: CNC Milling Melt Face With the Sienci Mill One
Model from: http://www.thingiverse.com/thing:651829
This project was milled using the Sienci Mill One!
Material: Pink Foam
Tooling: 1/8" Ballmill
Feedrate: 1200mm/min
Plunge rate: 400mm/min
Step down: 3mm/pass
Time to complete: Approximately 2 hours
CAM software: https://grid.space/kiri/?sm:CAM
Gcode sender: https://github.com/winder/Universal-G-Code-Sender
Order the Sienci Mill One: https://www.kickstarter.com/projects/sienci/sienc...
Machines start from $399US (full kit)!
Step 1: Setting Up CAM
Kiri:Moto is a simple, easy to use CAM software that works with STL files.
Check out the Youtube video to learn about how to use it!
Step 2: Sending Gcode
Kiri:Moto generally defaults to having the origin point at the top centre of the material. Set up your machine to the appropriate location and zero the machine.
Kiri:Moto has a gcode sender built into it's exporter.
Universal Gcode Sender is also a great option.
Happy milling!
