Introduction: CNC Polygon Shelf
Today I want to present you a polygon shelf.
Only the "connectors" need to be milled.
All you need is a saw and a cnc mill.
I don't think every project needs a long explanation.
Modular design, holds together by gravity.
80kg weight on top -> no problem
If you want to build it I will attach my files (step. and Fusion file including my milling operations) at the end of this instructable.
Material: 18mm plywood
- 3x 160cmx35cm
- 4x 47cmx42cm
- 2x 42cmx23cm
Step 1: Design With Fusion
Step 2: Prepare Milling Operations
Step 3: Assembly
No tools needed
just stick everything together
Step 4: Files
Thanks to everybody which thinks about building one ;)
if you don't know how to create milling operations please check out other instructables like this one:
https://www.instructables.com/Fusion-360-CAM-Tutor...
(great instructable)
or this one:
Milling handbook by Autodesk:
