Introduction: CNC Wooden Ring
In this tutorial, you will learn how to make a wooden ring using a CNC machine. Here is a list of the items you will need:
-Pencil
-Ruler
-Scissors
-Piece of Paper
-Block of Wood
-Sandpaper
-Wood Stain
-CNC Machine
-Design Software
-Coding Software(optional)
Step 1: Finding the Size of Your Ring
Items you will need for this step:
-Pencil
-Scissors
-Paper
-Ruler
Using your scissors, cut a thin strip of paper. Wrap the strip of paper around the knuckle of the finger you want to wear the ring on. Ask a friend to mark where the paper overlaps using the pencil. Next, measure from the start of the strip of paper to the pencil mark using your ruler, this is the circumference of the inside of your ring, for example, mine was 2 1/8 inches. Next, divide this number by 2π or 6.14, I recommend rounding your final number to four digits. This will give you the radius of the inside of your ring, for instance mine was .3382 inches.
Step 2: Designing Your Ring - Step 1 -
Things you will need for this step:
-Design Software
Using your design software(I used AutoCad), draw a circle with the radius you found in the previous step.
Step 3: Designing Your Ring - Step 2 -
Next, draw a larger circle around your first circle with a radius 1/4 inch larger than the inner circle.
Step 4: Designing Your Ring - Step 3 -
For the third step, draw two vertical lines starting at the left and right quadrants of the outer circle and ending even with the top quadrant.
Step 5: Designing Your Ring - Step 4 -
Next, trim the outer circle between the two vertical lines you just made.
Step 6: Designing Your Ring - Step 5 -
Finally, connect the two vertical lines with a horizontal line.
Step 7: Coding Your Ring
Using your preferred coding software(I used SpectraCam), code your piece so that it is a third of an inch thick. You can also code it manually if you prefer.
Step 8: Cutting Out Your Ring
-CNC Machine
Using the code you made in the last step, cut out your ring in the desired wood material.
Step 9: Facing the Wood
If the wood you have is thicker than your ring, flip over your wood and face it to the end of the ring. When facing, start from the middle of where the ring is and work out. If you do not work from the inside out, the ring will pop out however it will not be completely faced.
Step 10: Sanding Your Ring
-Sandpaper
Using your sandpaper, smooth out your ring until you are satisfied with the finished product.
Step 11: Staining Your Ring
-Wood Stain
Using your preferred color of wood stain, apply a few coats with a Q-Tip or small brush. Let the ring sit over-night so that the stain can set.
Step 12: Finished Ring!
You're now all done! You now have a unique wooden ring that you can wear or display. Thanks for reading!
