Introduction: PRINTED CNC Z AXIS for ARDUINO Projects or Small Router, Printer.
A small Z axis slider for small your small projects.
It use a nema 14 stepper and simple components.
You can buy the mechanical kit here: http://www.cnc4newbie.com
Or you can buy from your local hardware store.
Download the STL files from my thingiverse: http://www.thingiverse.com/thing:760793
Material need:
1x ABS slider
1x ABS body
2x 6" rod 5/16" diameter or use 8mm and adjust the holes with a 8mm drill
1x 5" threaded rod 1/4-20 or use 6mmx1mm and adjust the coupler
1x 1/4-20 nut or 6mmx1mm nut if you use metric threaded rod
1x coupler, it must match the threaded rod and the motor shaft, you can print one!!
4x flat head 3mm x 8mm screw
4x flat head 4mm x 14mm screw
4x 4mm nuts
1x flange bearing 6mm x 12mm
4x set screw 4mm x 5mm
1x aluminum 2"x3" front plate with 7 4mm threaded holes
1x nema 14 stepper
Voila!!
Please Vote for my slider in the 3D contest!
Thank you all!
EXCUSE FOR MY ENGLISH!!
Step 1: Video!!
Sorry for the bad quality video!!
Step 2: ABS PARTS
Print the ABS parts, make attention for not warping the parts.
Step 3: Assembly
start to assemble the parts.
First insert the nut and place the thread rod.
Install the coupler.
Step 4: SLIDER
Insert the bearing in the body.
Install the slider/threaded rod in the bearing.
Step 5: MOTOR
Now install the motor with the 4 flat head 3mm screws.
Step 6: SMOOTH RODS
now it's time for the smooth rods.
If the holes in the body or slider are to tight, adjust with a 5/16" drill or 8mm drill if you use 8mm rod.
Set the 4 small set screws, don't over tight!!
Step 7: FRONT PLATE
Mount the front plate with 4 flat head 4mm screws and nuts.
The nuts are mount in the hexagonal under the slider.
Step 8: VOILA!!
Voila!!
Now you have a nice slider for your arduino or small cnc projects!!
Hope you like!!
Jbc
3D Printing Contest
30 Comments
4 years ago
Hey hello, I was wondering if you have a SolidWorks model for the printeable parts or if you could write me down de exact dimensions or something like that :D I would really like to do it but I'll machine it with aluminum in a CNC
Reply 4 years ago
Hi, I have the file only for inventor but you can easily convert the stl files to cad format.
Jbc
6 years ago
Stay tune, in few days I will post a full 3 axis micro mill, Made from laser cut ply and ABS printed parts.
Jbc
Reply 6 years ago
The ply/abs router will be ready in few days!!
Jbc
6 years ago on Step 2
I printed the parts. It came out Awesome. Now trying to source other parts locally in SA.
Tnx fer de design!
73 de ZS6COG
Reply 6 years ago on Introduction
Nice too see that! If you need the metal kit, let me know I can help!
Thank you!
Jbc
Thanks for offering JBCRD
I sourced the parts locally. It was a pain.
I added a second printing head to my 3D printer and now it keeps on knocking the work parts over. I have to align the heads, but time eludes me.
Right now I am in the middle of re-building a thing for the science centre and it is a challenge.
Thanks again.
73
hi, you can post picture of your unit if you want!
Thank you!
Jbc
6 years ago
Hello, I have built all the hardware: physical structure, and have completed in entering the GRBLtoArduino and all the software. I have used the Universal GCodeSender and has successfully interpreted the software for is says " Grbl 0.8c ['$' for help] ". I've soldered the stepper motors (for I'm using steppers from dvd roms) to some salvages wire from a printer I took apart. I installed some female sockets in order to connect to the male pins on the CNC Shield ver. 2.01 . The orange light from the arduino flashes and in the Universal GCodeSender ver. 0.8 completes the operation b/c is says " ok " . I have no idea whats wrong. I know the steppers work b/c ive used a 9v battery to pulse the motors and they do indeed pulse. Ive used a multimeter to check its resistance and it works. I've checked the current on the motors once connected to the cnc shield and there's current. I have tested if the drivers are in fact getting power and they are. I've attempted the code " x=100 " , " $7=225 " but no motor movement. Can ANYONE help me ?
Hi, your motor is unipolar or bipolar? You use pololu driver?
Jbc
Reply 6 years ago
Bipolar and yes A4988. I couldn't find any data sheet on the stepper motors I'm using, dvd rom's, but many say they are 2-2 Phase. Is that the same as 2 A/Phase ? The drivers continuous current let phase is 1.2 A.
do you have try this sample test? http://fritzing.org/projects/a4988-single-stepper-...
Reply 6 years ago
So I simply type those commands into the Arduino application running Grbl ?
Plug all the wires like the drawing and enter the code.
Do you use an UNO or Mega? What shield you use?
Jbc
Reply 6 years ago
I use a Fundiuno Uno , CNC Shield ver. 2.01, drivers: A4988.
make the simple test in the link for testing your hardware.
It's really fast ans simple to do!
Good luck! And let me know.
Jbc
Reply 6 years ago
Okay . I could simply uploaded through the arduino application onto the arduino ?
any news?
Jbc
Reply 6 years ago
Hello it did nothing
7 years ago on Introduction
That looks Awesome, Great and Very Professional looking too!
I am going to make or Buy a small Vertical Mill and I was wondering if I could save some money by making something like this to work with the CNC Vertical Mill? I wonder if I could program this unit to Hold an Aluminum Object & slowly move it to a set point and stop, then raise up 1/16" and have it return to it's original starting position, to gradually have it cut down to a certain depth in the aluminum and have it stop? Basically wondering if I could make an Automated CNC Table so the Vertical Mill could just Cut while this unit moves the part being slowly cutdown to a specific size? Could I program a unit like this from a Laptop to complete that?
Thank you in advance.
A video of this Unit working in action with a Mill or Drill press would be Nice to see? Or a 3D printing job.
This is Awesome
