Introduction: CNI Beam Expander
About: Changchun New Industries Optoelectronics Tech. Co., Ltd. (CNI), founded in 1996, is the largest manufacturer and supplier of diode pumped all-solid-state lasers (DPSSL) in China. CNI produces CW, modulated a…
A beam expander is any optical system designed to increase the diameter of a laser beam. In most cases, the term is taken to mean a telescope designed to take a small-diameter collimated beam input beam and produce a larger diameter collimated output beam, thus reducing the divergence of the beam. The beam expander consists of a negative input lens and a positive objective. The expansion factor is the ratio of the focal length of the two lenses.
Features:
Low power loss
Good output collimation
Able to withstand laser power of more than 1000 W
Adjustable divergence angle of 18 to 32 mrad with the variable beam expanders
Applications
Precision laser machining: capable to provide a high power density focal spot
Laser range finder: capable to provide a highly collimated beam
Combining with a spatial filter, able to modify laser power distribution
Step 1: BE Series Beam Expander for Beam Size of ≤2mm Diameter
Specifications
Part No. Expansion ratio Dimensions (mm)
BE-2x 2X Φ25*50
BE-3x 3X Φ25*50
BE-5x 5X Φ25*50
BE-10x 10X Φ30*65
Step 2: BEW Series Beam Expander for Beam Size of 4-10mm Diameter
Specifications
BEW-2x 2X Φ29*51
BEW-3x 3X Φ36*74
BEW-5x 5X Φ46*109
BEW-10x 10X Φ86*197
