Introduction: CNI Fiber-coupled LEDs
About: Changchun New Industries Optoelectronics Tech. Co., Ltd. (CNI), founded in 1996, is the largest manufacturer and supplier of diode pumped all-solid-state lasers (DPSSL) in China. CNI produces CW, modulated a…
Features
■ UV, Visible, and NIR Versions (from 375nm to 940nm)
■ The SMA connector is ideal for multimode fiber.
■ PSU-III-LED or PSU-M-LED is optional.
Data sheet
color Nominal Wavelength(nm) Bandwidth FWHM (nm) Typical Φ600um Core Fiber output Power SMA(mW) Maximum Current CW(mA) Forward Voltage(V) Typical Lifetime(h)
LFM375 UV 375 16 3 700 3.4 >10000
LFM400 UV 400 11 5 1000 3.8 >10000
LFM405 UV 405 12 4.2 700 3.8 >10000
LFM435 Violet 435 15 4.5 700 3.6 >10000
LFM460 Royal Blue 460 25 6 1000 3.6 >10000
LFM470 Blue 470 20 3.2 1000 3.4 >10000
LFM500 Cyan 500 30 2.2 1000 3.2 >10000
LFM520 Green 520 25 2.5 1200 3.4 >10000
LFM600 Amber 600 15 1.2 1000 2.6 >10000
LFM620 Red 620 15 5.5 1200 2.5 >10000
LFM660 Deep Red 660 20 4 700 2.4 >10000
LFM850 IR 850 25 3 700 2.2 >10000
LFM940 IR 940 30 2 700 1.6 >10000
Note: 1.When the operating current, temperature or other parameters are different, the actual spectrum of LED may change, so the above parameters are only for reference. 2.The above data was tested by 600μm core diameter, 0.22 NA multimode fibers. For more different core diameter fibers testing data, please contact customer service.
Step 1:
