Introduction: CNI Laser Power Meter
CNI launched a thermoelectric laser power meter, which is able to accurately measure various laser power. The thermoelectric laser power meter is equipped with PC software to store measured data, easy to operate and portable built-in rechargeable battery.
CNI as the international leading designer and manufacturer of laser system, fully understands customers’ actual demand for laser power measurement and analysis, a few series of customized power measurement instrument can be offered. CNI sincerely provides with best configuration which can meet customers’ demand of measurement and funding level based on the actual application understanding, advanced technology and measuring instrument selection. In order to make customers gain higher cost performance,CNI offers modular selection which can easily extend configuration in future demand change.
Step 1: Thermopile Laser Power Meter
Features:
Large, bright, backlit LCD display
Wide range and high precision measurement
Connect with PC, Data recording, statistics and mean function, drawing, the trend picture using sampling software Long-term stable measurement
Built-in rechargeable battery, long standby time
Easy to operate
TS series
TS 2 (2mW-2W) TS 5 (2mW-5W) TS 15 (5mW-15W) TS 35 (10mW-35W) TS 50 (10mW-50W) TS 100 (15mW-100W)
Wavelength range: 0.19-25µm
Power range:2mW-100W (2W/5W/15W/35W/50W/100W selectable)
Thermopile with high damage threshold (Max. average power density: 40kW/cm2 ) Max. Intermittent measuring time: 8min (at 50W)
Sensitivity diameter ≥ 22mm
Step 2: High Precision Photoelectric Laser Power Meter
Model PS100
Detector Model PD-MN-100
Power Range 10nW -100mW
Sensitive Diameter 8mm
Detector Material Si photodiode
Wavelength Range 320-1100 nm
Measurement Display nW/µW/mW/dBm/dB
Sensitivity 0.001nW
Uncertainty(k=2) ±5%
Response Time (0-90%) <2sec.
Linearity ±5%
Total Weight 0.8kg
Instrument Power 100-240 VAC, 50/60 Hz, DC 9V-1.4A
Temperature (Operating) 5℃-45℃ (41℉-113℉)
Temperature (Storage) -20℃-70℃ (-4℉-158℉)
