Introduction: CNI Optical Spectrum Analyzer
Spectroscopy is a branch of optics, studying the generation of spectrum of various substances and its interaction with materials. Spectroscopy technology is not only a scientific tool, it also provides an important method of qualitative and quantitative analysis in the chemical analysis. Spectroscopy technology works by measuring the light intensity of ultraviolet, visible, near infrared and infrared wavelengths, is widely used in scientific research, teaching, industrial and many other fields. CNI offers laser, spectrometer, software analysis and other products, also provides customized products according to customers’ demands.
Step 1: High Resolution Spectrometer Aurora4000
Features:
Up to 0.02nm(FWHM) optical resolution
Convenient operation
Customized wavelength range and resolution
Fit various applications
Support download for Spectral Analysis 5.0
Applications:
Laser spectral analysis
Fluorescence spectral analysis
Raman spectral analysis
Film thickness measurement
Chemical research
Reflectivity/transmittance measurement
Biological cell analysis
LED analysis
Absorbance measurement
Detector
Detector Toshiba TCD1304DG linear CCD array
Wavelength range 200-1100nm
Pixels 3648 pixels
Pixel size 8um*200um
Sensitivity 130 photons/count at 400nm 60 photons/count at 600nm
Spectrometer
Dimensions (mm) 149*105*46
Weight (g) 840
Optical resolution <0.75nm FWHM
Signal-to-noise ratio 300:1 (at full signal)
Dark noise 12RMS counts
Dynamic range 2*10ˆ9(system);1300:1 for a single acquisition
Integration time 4ms-10s
Stray light <0.05%@600nm; <0.10%@435nm
Corrected linearity >99.8%
Optical Bench
Design f/4, Symmetrical crossed Czerny-Turner
Focal length 101.6mm input and output
Entrance aperture (um) 5,10,25,50,100 or 200
Grating A variety of different grating, ultraviolet and infrared
Fiber optic connector SMA905 to 0.22 numerical aperture single-strand fiber
Electronics
Power consumption 450mA@5VDC
Trigger mode 4 species
Data transfer speed Full scans into memory every 4 milliseconds with USB 2.0; every 18 milliseconds with USB 1.1
Inputs/outputs 5 inputs and 5 outputs (opto-isolator inputs/outputs)
Analog channels One 12 analog input one 12 analog output
Connector 30-pin connector
Step 2: High Resolution Spectrometer-Sunshine
Features:
Applications:
LIBS spectral analysis
Textile industry
Chemical analysis
Medical diagnosis and detector
Detector
Detector Hamamatsu S 11510
Pixels 2048 pixels
Pixel size 14um*14um
Spectrometer
Dimensions (mm) 149*109*50
Weight (g) 1000
Optical resolution 0.035-0.6nm
Signal-to-noise ratio 10000:1
Integration time 17ms-10s
Electronics
Strobe functions Yes
Step 3: Compact Spectrometer Firefly4000
Features:
Small appearance, easy to carry
Applications:
Food and agriculture
Chemical or biological research
Environmental sciences
Detector
Pixels 3648 pixels
Spectrometer
Dimensions (mm) 89*63.9*36.2
Weight (g) 170
Optical resolution <0.6nm
Electronics
