Introduction: CO2 Drain Cleaner Hack
A while back, we had a slow running drain that seemed to be permanent. I came across a product called "Kleer Drain" that uses CO2 cartridges to blast through clogs. I thought it was worth the attempt, so I picked one up at Home Depot.
Boy, did it work... Not only that, but it made an extremely satisfying "whump" sound that sent me out to the hardware store to pick up more cartridges so I could attack all of our drains, plugged or not.
The problem is, the device also requires a single shot plastic disk that allows pressure to build up before it bursts. When it does, the resulting explosion is what actually blasts through the clog. These disks are no where to be found, except from the manufacturer... And they're both pricey and in short supply.
They look like Tyvek, but they're not. Tyvek doesn't burst under CO2 pressure. Certain types of paper may work, but when I thought about the work of having to cut all those disks out, I came up with a better solution that seems to work pretty well:
Step 1: How Kleer Drain Works
I love this device, but it has some flaws. First is the need for CO2 cartridges. The Kleer Drain comes with a couple, but if you're like me, you'll use them all up in an hour or two. Trust me... This thing is fun to use:)
The same goes for the plastic disks, but they aren't so readily available. The only place I was able to find them was on the manufacturer's website. And they cost a gazillion dollars for a half dozen... And they only came with additional cartridges (which cost another half gazillion).
I think the company may be using the inkjet printer profit model... sell the printer at cost and make money on the ink. I have no problem with that, but I don't want my fun eating up my savings, or discover I don't have the parts I need in an emergency.
Enough commiserating, lets hack a solution!
Step 2: Materials
Here's what you'll need:
1. Kleer Drain clog remover... I notice these things are getting more difficult to find. Maybe someone reading this can make one in an Instructable out of PVC pipe. If so, the syringe will perform the same with a diy device as well.
2. 12cc hypodermic syringe. I use syringes for everything from dispensing paint, grease, diamond paste and WD40. Glass syringes make excellent dispensers for solvents. You can't have too many of these things. You won't need a needle for the one we'll be using, only the housing and plunger parts. Your local hospital might give you used syringes for free.
3. Razor knife
4. Hose washer
3. Razor knife
4. Hose washer
Step 3: Build
Start by cutting off the bottom portion of the syringe housing. This will allow the plunger to pop out of the end, explosively releasing the pressurized gas behind it. Remove any left over flashing around the inside edge. This will prevent damage to the soft rubberized gasket at the bottom of the plunger as it gets shot out of the syringe.
Slide the hose washer over the syringe and bring it all the way up as far as it will go.
Depending on the style of syringe you use, you might need to trim the finger holder portion so it fits inside the pressure chamber pocket of the Kleer Drain. Trim only as much as necessary, leaving enough surface to insure a good seal. The 12cc size syringe fits nicely through the hole in the pressure chamber. A smaller syringe would fit as well, but the volume of CO2 that rushes through it would be severely reduced, turning that satisfying "whump" into a disappointing "fizz".
Finally, cut away the "thumb button" on top of the syringe's plunger. If it's left on, it will re-seal the pressure chamber when the plunger pops out of the bottom. If that happens, you won't get the explosion you're expecting.
Step 4: Using the Hacked Kleer Drain
Insert a CO2 cartridge and you're ready to go. One bit of advice from experience. If the sink you're trying to unplug has an overflow drain like ours does, either plug it up, or use the plastic protection sheet that comes with the Kleer Drain. Failure to do this will do 2 things...
1. Do a beautiful job of cleaning the gunk out of your overdrain system, and
2. Give you a close-up view of what sink gunk looks like exploding out of the sink, ricocheting off the walls, your clothes and your face.
Also, remove any plug from the drain... Don't forget to re-screw the cover for the drain link that's under your sink, or you'll be cleaning that up as well... (Another bit of first-hand experience:)
Set the business end of the Kleer Drain into the drain and push down on the handles. As soon as the plunger makes the trip from the top of the syringe to the bottom, it will explode with the most satisfying sound you'll ever hear coming out of your home's plumbing.
With the plunger in the full up position, my device takes about 5 seconds after I pierce the CO2 cartridge to explode. The plunger can be set further down in the syringe to speed things up, but the explosion will be smaller.
Step 5: Update:
Well, I now know, this hack as initially described, will work about 15 times before the plastic holding the plunger gives up the ghost due to extremely high pressures (have I mentioned that I love this thing and use it just for fun?). I suppose, for most people, 15 uses is an entire lifetime's quota of needing a plumber's helper, so this is for those of us who believe play is more important than work.
Also, I've learned the type of CO2 cartridge sold as "soda chargers" don't work at all for this device. The cartridges that specifically say they are for Kleer Drain, are brassy in color and have a good sized exhaust hole (soldered over, of course) work the best.
For those who don't need a permanent solution and will only use this device a few times, kill-a-watt has sent me the direct link to Home Depot's site, where replacement disks can be ordered:
http://www.homedepot.com/Kleer-Drain/h_d1/N-uhZ5yc1v/R-100083282/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
For people like myself, I've developed a modification that will hopefully withstand the agressive explosions the Kleer Drain is exposed to whenever boredom leads to the inevitable "let's make an explosion" moment:
Minimum of what you'll need:
1. 1/2" Dowel
2. Bolt
3. Washers
4. Lock Nut
5. String
6. Duct Tape
First, size a washer to fit into the syringe's rubber plunger. If you haven't already blown it up, use the plastic fitting of the syringe to judge the size. IMPORTANT: Round any sharp edges of the steel washer that will be in contact with the black rubber plunger. The explosions it will be subjected to are violent and any help you can give it will help it's longevity.
Next, cut a short piece of dowel and drill a hole down through the center. I tried attaching the parts to them with wood screws, but each one split and destroyed itself the first time I tried them. A bolt will make use of the wood's compressive strength. As you can see in the photos, I'm using a brass rod, but wood should work just fine.
I'm also using a rubber shock absorber (nothing quite like over-kill, is there?), which may or may not be helping. Since the rod I'm using is heavy brass and being forced out at such a high rate (it actually blew through the small hole at the end of the Kleer Drain once), I figured a shock absorber couldn't hurt. Basically, it's a rubber tube that fits between the brass rod and the top washer.
Follow the exploded drawing to assemble the parts in order.
The string is taped to the outside of the syringe tube. Start by running tape over the string as it rests on the tube with its bitter end at the bottom. When the tape is in place, loop the string back down and run a second layer of tape over it again. This locks the string in place.
I've also added a shock absorber to the string. It's very simple... Once the string is taped to the cylinder and tied around the bolt at the bottom of the dowel, thread the center of it through these items, in this order:
1. small washer
2. spring from ball point pen
3. small washer
Now, thread a ring through the loop sticking out and you're done.
I've changed how I load the plunger into the syringe as well. Now, I recommend inserting it from the bottom. This will keep the pressure from trying to rip the plunger off of the washer. You'll also notice, I use removable putty inside the plunger to hold it in place.
Silicone grease will keep everything running smoothly.
After the Superbowl, I showed my buddy how it works... Now he wants one... oooRah!
1. 1/2" Dowel
2. Bolt
3. Washers
4. Lock Nut
5. String
6. Duct Tape
1. small washer
3. small washer
