Introduction: COCONUT SHEEL COSTUME
I HAVE MADE THIS FROM COCONUT SHELL WHICH I FOUND IT KITCHEN NEAR DUSTBIN.SO I THOUGHT OF MAKING IT'S USE AS HALLOWEEN COSTUME.
IT'S VERY SIMPLE TO MAKE AND DOESN'T CONSUMES MUCH TIME IN MAKING IT.
TO WEAR THIS SCARY STUFF ON YOUR CLOTHES,YOU WILL HAVE TO MAKE SOME MODIFICATION i.e YOU WILL HAVE TO INSERT LED INSIDE THE COCONUT SHELL AND MAKE IT BATTERY OPERATED.
Step 1: PART 1- ITEMS NEEDED
THE FOLLOWING ITEMS ARE:-
1) COCONUT SHELL (QUANTITY=12).
2) GELATIN PAPER PIECES.
3)STEEL WIRE (2 mtr approx).
4) GUM.
5) DRILL MACHINE.
6) MARKER.
7)RED COLOUR LIGHT.
Step 2: MAKING FACES ON COCONUT SHEEL BY DRILLING HOLES ON IT
TAKE THICK MARKER AND DRAW EYES AND MOUTH THE WAY YOU WANT.AFTER DRAWING,DRILL HOLES ON THAT MARK AND MAKE IT LOOK LIKE SCARY FACE AS SHOWN IN THE IMAGES ABOVE.
IN SAME WAY FOLLOW THIS PROCESS ON 11 OTHER COCONUT SHELL.
SO IN ALL MAKE 12 SCARY FACES ON COCONUT SHELL.
Step 3: STICKING GELATIN PAPER INSIDE COCONUT SHELL
AFTER DRILLING HOLES,STICK GELATIN PAPER FROM INSIDE AS SHOWN IN THE IMAGE ABOVE.
LIKE THIS,MAKE ELEVEN MORE DIFFERENT FACES ON COCONUT SHELL AS SHOWN IN THE IMAGE ABOVE. SO IN ALL MAKE 12 SCARY FACES ON COCONUT SHELL.
Step 4: PASSING STEEL WIRES THROUGH COCONUT SHELL
DRILL ONE HOLE AT THE TOP AND BOTTOM OF THE COCONUT SHELL.THEN PASS THE STEEL WIRES THROUGH THE 4 COCONUT SHELL THROUGH THE HOLES DRILLED AT THE TOP AND THE BOTTOM.
IN SAME WAY,PASS THE STEEL WIRES THROUGH THE REMAINING 4 COCONUT SHELL AND OTHER 4 COCONUT SHELL AS SHOWN I NTHE IMAGE ABOVE.
Step 5: INSERTING LIGHT IN COCONUT SHELL AND IT'S DONE!!!! NOW WEAR IT.
NOW WEAR THIS SCARY STUFF ON YOUR CLOTHES IN HALLOWEEN PARTIES.
