Introduction: COIN RING MACHING 2.0
THIS IS THE NEW VERSION OF MY COIN RING MAKING MACHINE MADE FROM SIMPLE SCRAP AND JUNK FROM AROUND THE GARAGE
SOME OF THE PARTS
WEED EATER ENGINE
ASSORTED NUTS,BOLTS, AND WASHERS
SOME STEEL ROD
SMALL AC MOTOR
PRINTER AND SCANNER PARTS
BEARINGS FROM HARD DRIVE
HINGE
BUNGEE CORD
ANGLE BRACKETS
BLOCK OF WOOD
AND SOME TIME
TOOLS USED
HACKSAW
DRILL
SCREWDRIVER
ANGLE GRINDER
PLIERS
TAPE MEASURE
Step 1: GENERAL IDEA
DISASSEMBLE WEED EATER ENGINE SAVE PARTS
REMOVE HEAD FROM ENGINE SAVE IT
CUT ENGINE BLOCK TO EXPOSE CRANKSHAFT
RILL HOLE TO THREAD BOLT INTO TO ACT AS HAMMER PIVOT
MOUNT TO WOOD BASE WITH BRACKETS
BEND SOME ROD AND MOUNT HEAVY BOLT TO ONE END TO ACT AS HAMMER AND ATTACH OTHER END TO FAR SIDE OF ENGINE
MOUNT MOTOR HOOK UP BELT TO ENGINE
MOUNT ENGINE HEAD TO BASE ATTACH BRACKET TO HOLD AND ROTATE COIN PLACE BELT TO ENGINE SHAFT
LARGE CARRIAGE BOLT WAS USED IN HEAD FOR THE ANVIL HELD IN PLACE WITH EPOXY
APPLY POWER
PHOTOS OF COINS WERE USED FROM LAST PROJECT NEW PHOTOS WILL BE ADDED FROM THIS PROJECT WHEN TIME PERMITS IT WAS 1:30 AM AND EVERYONE WAS A LITTLE TIRED OF HEARING THE MACHINE RUN
Step 2: IN THE END
TIME SPENT FINDING PARTS AND BUILDING MACHINE APPROX. 2 HOURS
TIME TO HAMMER COIN 15 MINUTES TO THE POINT I WAS AT END OF VIDEO EXPECTED TIME TO HAMMER TO COMPLETION 30 MINUTES
PROJECT COST $0.00
ALL PROJECTS I MAKE I TRY TO SALVAGE ALL PARTS AND USE EASY TO FIND PARTS AND JUST A FEW TOOLS MOST PEOPLE OWN SO ALMOST ANYONE CAN DO THIS
