Introduction: CONTINUITY TESTER
This project is for the tests of AWG - THW - AND OTHER Cables to measure the continuity of these and also for the direct and inverse measurements of semiconductor diodes, leds, etc.
PROTEUS SIMULATION:
https://mega.nz/file/KApAmL5Z#0aPUw674HWF4oZMrLesarDPu8mfLLN0cXLOZ8l0aGBY
DATA SHEET 2N2222A :
https://mega.nz/file/WMxSlR4Q#SGr1-7vMqierASA0Hcg9LfApns8LZve_StoxmiV9q8s
Step 1: SCHEMATIC DIAGRAM
Here we will see the simulation of our project and we will make the circuit to be used, which is a CABLE - DIODE CONTINUITY TESTER.
In the image we can see that we tested a 1N4007 semiconductor diode in its direct and inverse test, resulting in a successful test thanks to the design of our circuit.
This circuit is implemented using transistors, resistors, a led diode and a capacitor. The operation is very easy to appreciate since in a direct conduction, either testing a diode or a cable, this will turn us on, giving continuity and making our led turn on, which will verify that it is conducting. In the case of the diode, it has two tests in the reverse test. It should not turn on since it does not let the positive current pass to the base of the first transistor and therefore it will not drive the transistors and it will not turn on our led.
Step 2: PCB Layout
Here we will be able to observe the design in the Easyeda Software for the creation of the PCB, this is a very professional software and we will be able to find all our components that we will need for this project.
In the images, once we have simulated it, we will carry it out on a very professional board thanks to JLCPCB (https://jlcpcb.com/RAV) and we will see the 3D design of how our PCB will look and we will also see the PCB tracks.
Step 3: ELECTRONIC COMPONENTS
* (2) 2N2222A TRANSISTORS
*(1) RESISTOR 100K 1/4W
*(1) RESISTOR 10K 1/4W
*(1) RESISTOR 1K 1/4W
*(1) RESISTOR 100 ohm 1/4W
*(1) LED DIODE 5mm
*(1) CAP. ELECTROLYTE 10UF 16V
*(1) 2PIN CONNECTOR
*(1) PAIR OF TEST LEADS
Step 4: CHARACTERISTICS
VIN 3.7V (18650 BAT)
TESTER OF ALL TYPES OF CABLES
SEMICONDUCTOR DIODE TESTER
LED DIODE TESTER
high efficiency tester
Step 5: PCBWay
PCBWAY has 10 years in the electronics industry manufacturing professional PCBs, assembling PCBs managing to satisfy the demands of all parts of the world, in addition to meeting the highest quality and delivery time standards. PCBWAY allows the manufacture of your PCBs from 5 units.
This project was carried out thanks to PCBWAY, a company dedicated to the manufacture of prototypes and professional PCBs, in addition to offering you a ready assembly service with all the components in your PCBS, complying with the established quality and delivery time standards.
We thank PCBWAY, a leading company for manufacturing and assembling professional PCBs with the highest quality, PCBWAY has fair reasonable prices, punctual shipping time and 24-hour customer service, it also offers you the option of quoting all its services in his web page. Do not think twice and start manufacturing your professional PCBs from 5 units safely.
10pcbs at $5 order them here www.pcbway.com
We thank PCBWAY for the professional pcb they provide us for this project.
