Introduction: CONTROL 8 LED USING ARDUINO :-
I hope you might have have practice my GETTING STARTED WITH ARDUINO #1 which showcased you the control of LED using Arduino.In this instructables i will teach how to control 8 Led simultaneously. so are you ready to build a colourful instructables??.Keep following for arduino ,HTML and CSS tutorial which will be published in a short while.
Step 1: ELECTRONICS REQUIRED :-
The most simple tools required for this colorful Instructables are:-
- Arduino uno
- Breadboard
- Jumper wires
- LED
I am eagerly waiting to get started!!!!!!.
Step 2: BUILDING ELECTRONICS :-
- Bend the cathode of all the 8 LED in such a way that the cathode is inserted in the power rail of the negative supply.Supply the ground pin from arduino to the negative railings
- The annode leg is connected to the digital pin of the Arduino[2,3,4,5,6,7,8,9]
it's finished now. let's get into the most difficult yet a easy task ' CODING '
Step 3: CODING :-
//LED Pin Variables
int ledPins[] = {2,3,4,5,6,7,8,9}; //An array to hold the pin each LED is connected to //i.e. LED #0 is connected to pin 2, LED #1, 3 and so on //to address an array use ledPins[0] this would equal 2 //and ledPins[7] would equal 9
/* * setup() - this function runs once when you turn your Arduino on * We the three control pins to outputs */
void setup() {
//Set each pin connected to an LED to output mode (pulling high (on) or low (off)
for(int i = 0; i < 8; i++){
//this is a loop and will repeat eight times
pinMode(ledPins[i],OUTPUT); //we use this to set each LED pin to output } //the code this replaces is below
loop() - this function will start after setup finishes and then repeat * we call a function called oneAfterAnother(). if you would like a different behaviour * uncomment (delete the two slashes) one of the other lines */
void loop() // run over and over again {
oneAfterAnotherNoLoop(); //this will turn on each LED one by one then turn each off }
void oneAfterAnotherNoLoop()
{ int delayTime = 100; //the time (in milliseconds) to pause between LEDs //make smaller for quicker switching and larger for slower
digitalWrite(ledPins[0], HIGH); //Turns on LED #0 (connected to pin 2 )
delay(delayTime); //waits delayTime milliseconds
digitalWrite(ledPins[1], HIGH); //Turns on LED #1 (connected to pin 3 )
digitalWrite(ledPins[2], HIGH); //Turns on LED #2 (connected to pin 4 )
digitalWrite(ledPins[3], HIGH); //Turns on LED #3 (connected to pin 5 )
digitalWrite(ledPins[4], HIGH); //Turns on LED #4 (connected to pin 6 )
digitalWrite(ledPins[5], HIGH); //Turns on LED #5 (connected to pin 7 )
digitalWrite(ledPins[6], HIGH); //Turns on LED #6 (connected to pin 8 )
digitalWrite(ledPins[7], HIGH); //Turns on LED #7 (connected to pin 9 )
//Turns Each LED Off
digitalWrite(ledPins[7], LOW); //Turns on LED #0 (connected to pin 2 )
digitalWrite(ledPins[6], LOW); //Turns on LED #1 (connected to pin 3 )
digitalWrite(ledPins[5], LOW); //Turns on LED #2 (connected to pin 4 )
digitalWrite(ledPins[4], LOW); //Turns on LED #3 (connected to pin 5 )
digitalWrite(ledPins[3], LOW); //Turns on LED #4 (connected to pin 6 )
digitalWrite(ledPins[2], LOW); //Turns on LED #5 (connected to pin 7 )
digitalWrite(ledPins[1], LOW); //Turns on LED #6 (connected to pin 8 )
digitalWrite(ledPins[0], LOW); //Turns on LED #7 (connected to pin 9 )
delay(delayTime); //waits delayTime milliseconds }
void oneAfterAnotherLoop(){
//Turn Each LED on one after another
for(int i = 0; i <= 7; i++){
digitalWrite(ledPins[i], HIGH); //Turns on LED #i each time this runs i
delay(delayTime); //gets one added to it so this will repeat } //8 times the first time i will = 0 the final //time i will equal 7;
//Turn Each LED off one after another
for(int i = 7; i >= 0; i--){ //same as above but rather than starting at 0 and counting up //we start at seven and count down
digitalWrite(ledPins[i], LOW); //Turns off LED #i each time this runs i
delay(delayTime); //gets one subtracted from it so this will repeat } //8 times the first time i will = 7 the final //time it will equal 0 }
/* * oneOnAtATime() - Will light one LED then the next turning off all the others */
void oneOnAtATime(){
int offLED = i - 1; //Calculate which LED was turned on last time through
if(i == 0) { //for i = 1 to 7 this is i minus 1 (i.e. if i = 2 we will offLED = 7; //turn on LED 2 and off LED 1) } //however if i = 0 we don't want to turn of led -1 (doesn't exist) //instead we turn off LED
7, (looping around)
digitalWrite(ledPins[i], HIGH); //turn on LED #i
digitalWrite(ledPins[offLED], LOW); //turn off the LED we turned on last time
delay(delayTime); } }
/* * inAndOut() - This will turn on the two middle LEDs then the next two out * making an in and out look */
void inAndOut(){
int delayTime = 100; //the time (in milliseconds) to pause between LEDs //make smaller for quicker switching and larger for slower //runs the LEDs out from the middle
for(int i = 0; i <= 3; i++){
offLED = 3; //turn on LED 2 and off LED 1) } //however if i = 0 we don't want to turn of led -1 (doesn't exist) //instead we turn off LED 7, (looping around)
int onLED1 = 3 - i; //this is the first LED to go on ie. LED #3 when i = 0 and LED //#0 when i = 3 int onLED2 = 4 + i; //this is the first LED to go on ie.
LED #4 when i = 0 and LED //#7 when i = 3
int offLED1 = 3 - offLED; //turns off the LED we turned on last time
int offLED2 = 4 + offLED; //turns off the LED we turned on last time
digitalWrite(ledPins[onLED1], HIGH);
digitalWrite(ledPins[onLED2], HIGH);
digitalWrite(ledPins[offLED1], LOW);
digitalWrite(ledPins[offLED2], LOW);
delay(delayTime); }
//runs the LEDs into the middle
for(int i = 3; i >= 0; i--){
int offLED = i + 1; //Calculate which LED was turned on last time through
if(i == 3) { //for i = 1 to 7 this is i minus 1 (i.e.
if i = 2 we will
offLED = 0; //turn on LED 2 and off LED 1) } //however if i = 0 we don't want to turn of led -1 (doesn't exist) //instead we turn off LED 7, (looping around)
int onLED1 = 3 - i; //this is the first LED to go on ie. LED #3 when i = 0 and LED //#0 when i = 3 int onLED2 = 4 + i; //this is the first LED to go on ie. LED #4 when i = 0 and LED //#7 when i = 3 i
delay(delayTime); }
