Introduction: COVID-19 Face Shield
In order to help with the critical shortage of personal protective equipment (PPE) during the corona virus pandemic, we're making hundreds of face shields to give to first responders, nurses and doctors who are on the front lines.
We made a face shield from a piece of polycarbonate and a baseball cap. We geared up to making them by the hundreds but a simple one can be done with only a few tools, an old baseball hat and some plastic.
Here's the video of how to make one
https://youtu.be/grXbSme6kTY
Step 1: Supplies and Tools
Supplies:
- baseball cap
- piece of .03" polycarbonate*
- piece of cardboard or sheet metal to make template (if you're making lots of them)
Tools:
- tin snips
- utility knife
- sheet metal pliers or an aluminum block with a slot milled in it (for people making lots of them)
- pencil
* If you're making just one, plastic from prepackaged salad greens, soda bottle or laminating pouches can also work
Step 2: Marking the Hat
Cut out the template from sheet metal or cardboard. Then use a pencil to mark the hat in four places
Step 3: Cutting the Hat
Cut slits at the four pencil marks you just drew on the hat
Step 4: Fold Back the Brim
Fold back the brim on the hat using a sheet metal pliers (or anything else like a pliers, vise grips that works). Fold it back until it's at about 90 degrees to the brim. You want to fold about 1/2" or just about the length of the slits
If you have an aluminum block, just put the prim in about half an inch and fold it backwards. After removing the hat from the block, push with your thumbs so the brim is folded back just less than 90 degrees
Step 5: Cutting and Bending the Plastic
We cut our polycarbonate with a CNC router but if you're making just one, a scissors, utility knife or tin snips can work. Cut out the plastic according to the file included. And then cut the two slots near the top of the shield. Bend the plastic which helps hold the shield in the cap. We used a press brake but you can easily fold it by hand
Step 6: Attach the Plastic to the Hat
Start at one side and slip the plastic into one of the side notches. Then pull the plastic tight and slip it into the notch on the other side.
Step 7: Bend Up the Tabs
After you insert the plastic into the hat, bend up the pointy corners with your hands or a pliers to "lock" the shield in place
Step 8: Remove the Plastic Sheet
and your hat is complete
Step 9: Make More and Get the Word Out
You now know how to do it - so find some friends to help make more and get them to all the health professionals who need them
If you know any health professionals who want them, we're distributing them for free. You can contact us at:
personalprotectiveequipment@gmail.com
or request shields at:
