Introduction: COVID 19 Simplest of Face Shield
Hello
Here is a very simple design to make a face shield.
It only uses one printed part, one standard A4 transparent plastic sheet and whatever you want / have as fixation (elastic band, tissue, cord,...)
No trimming, no cutting, no glue or other parts needed.
Help healthcare workers!
Thanks!
Thomas Schubert
Step 1: Print Parts
I designed it in two sizes but it seems that the medium one fits most.
Print it with the writing upside down. There is a small cleft that has to be on the upper part.
Step 2: Inserting the Screen
You can use those A4 plastic sheets that are used to make syllabus covers, books, etc. Any plastic sheet that is transparent, A4 size, thickness between 200µm and 500µm, no cutting needed.
As you can see on the image, the plastic sheet is wedged on its longest side in the cleft. It is pushed as far as possible.
Easier to start on one side to first slide it in then firmly push it in position.
Step 3: Straps
It is designed to accommodante almost everything: cord, bungee, elastics, straps of fabric, whatever works for you.
