Introduction: CS:GO Case
Weapons case from CS:GO. This one is printed in PLA on a Wanhao Duplicator i3 with the following settings:
- Layer Height (mm): 0.1
- Shell thickness (mm): 1.2
- Bottom/top thickness (mm): 1.2
- Fill Density (%): 15
- Print speed (mm/s): 50
- Printing temp (C): 200
- Bed temp (C): 70
- Support type: Touching buildplate
You will need 2x screws to secure the lidd to the case. Or you can use a string.
The mark in the front, I used a silhouette cameo to cut out the icon found on google, but you can just as easy cut it by hand.
