Introduction: CTHULHU CAR DECAL!
In this instructable I will show you how to make a plastic logo thing for your car. I made mine depicting "The Great Cthulhu" as an Icthys Fish, but you could do whatever you want. This is an easy, simple instructable.
Step 1: Material
For this project you will need:
Plastic suitable for the type of cutting you will do. (The more intricate your design, the easier the plastic needs to be to cut)
A knife or set of knives. I got a set of Xacto knives with a bunch of blades for $3 at Menards.
A template for cutting.
Spray paint for coloring.
Step 2: The First Step.
Trace your template onto whatever you will be making the decal out of. If your plastic wasn't transparent like mine then I guess you could tape the template on and cut both plastic and paper.
Since my project required 2 layers,one as a background, one as the shape and the letters, I cut the background slightly larger than the foreground and left it solid. For the foreground I cut out around the letters, but left the top and bottom attatched to the "body" of Cthulhu to make it easier to glue. I did all the cutting while watching "In Bruges" (great movie, by the way)
Step 3: Painting.
Time to paint the logo! I used outdoor type spraypaint. Make sure to give a smooth, even coat. Otherwise your decal will have ugly bubbles and thicker areas of paint. I kind of messed up on the silver area, but it still looks okay.
Step 4: Final Step
Almost done! Now you need to glue the two pieces together, if you used two layers. I used JB weld because it was the only thing I could find, but Krazy glue would probably be better.
Once you are done, find a way to attatch it to your vehicle of choice. Glue, magnets, some kind of adhesive foam backing, its your choice. Once I get a car, this thing is definitely going on there, and I'll see if I can find some other H.P Lovecraft fans.
