Introduction: Cable Holder for Desktop
How to make a simple desktop cable holder,
- Holds the cable securely
- Low friction, the cables slide easily in and out
Step 1:
Materials:
1. a piece of plastic from a shampoo bottle or similar ( HD-PE or PP plastic ),
size depends on which template is used.
2. a steel tablecloth clamp / clip
Step 1:
- cut out the plastic piece and flatten it
- print out one of the templates below and tape it on the plastic piece
(the templates also include other designs if you don't like feet on the table.. :-)
PDF Template for 50 mm clips ( 2 inch )
PDF Template for 75 mm clips ( 3 inch )
- make the holes and make a surface mark through the cutting lines
with a sharp knife
Step 1:
with a sharp knife
Step 2:
Remove the template and cut out the plastic piece .
Step 3:
- Mount the parts and fasten to the edge of the table
- slide in the cables at about 45 degree angle for easy mounting
Link to the original DIY page :
http://www.benvelo.com/cableholder_desktop.htm
More of my DIY tips :
http://www.benvelo.com/diy.htm
