Introduction: Cable Drum Coffee Table
Have seen a few of these coffee tables on the Internet etc so thought I would have a go.
Step 1:
Materials required
1. Cable drum
2. 25.4mm dowel
3. Paint
4. Clear coat
5 3 castors
First step in my case was to insert a replacement board as one had come away. Luckily I had some thin pallet boards that were pretty much an exact fit, I just glued and clamped this and then used a jigsaw to shape it.
Second step is to tidy up any protruding nails, either punching them in, or extracting them if you can. This requires a bit of judgement.
step 3 is to sand all over I went from 80 to 120 to 180 grit,
Step 4 is then to round over the edges and any sharp points. I could have used a router but just decided to use a detail sander
Step 2:
Apologies for the huge jump in photos - I did take some of the following steps but cannot find them!
Next step is to decide which side is best to use as the top. In my case it was fairly easy as the replacement plank meant the other side was better as the top.
Now, turn your drum over so the bottom side is facing up,
now measure the height of the gap between the underside of the 'top' and the underside of the bottom. Now cut your dowel into 6 pieces of that length. You could do more uprights if you like.
Now measure the distance from the core of the drum to the edge and divide by 2. You can now measure in from the edge and mark where to drill the holes for the dowels, obviously spacing these equally.
I used a spade bit to drill the holes through the underside of the cable drum and then simply tapped the dowels through until they hit the 'top'. They felt tight enough not to require securing at the other end.
Now fix your castors in place - space them equally a couple of inches in from the edge. Now turn it over and it starts to look like the finished product.
Once done, it's time to start painting! Go for your life.
Step 3:
I needed a good coat of primer and then good couple of coats of paint to get the required finish and then put a clear coat on top to add durability.
On reflection I probably should have used thinner dowel and more of them to help books stay upright, but that would make painting a bit trickier.
6 Comments
7 years ago
Good spot woody2822 - we are actually down in the southwest where I now have time to do stuff like this now I have escaped the big city!
7 years ago on Introduction
I have that book! you from Perth to?
7 years ago on Step 3
I love it! Very clever to add the dowels - makes it even more functional.
This is so great!
7 years ago
Thank you and I agree chienline - would work well with just a clear coat for the real industrial look....I used a semi gloss clear coat on this but might try a full gloss next time.....
Beautiful ... Love it. It is already nice without painting. Some clear coats will do.
