Introduction: Camera NanoTank
This intructables show how to use Seeed Studio XIAO ESP32S3 and corresponding camera module to build a NanoTank.
Seeed Studio XIAO ESP32S3 Sense
751626 Lipo Battery
DRV8833 Motor Drive Board
2 x Mini 3.7V 6mm Coreless motor (47RPM)
2 x 1 inch rubber band
4 x 12 mm flat head M2 Screw
(Optional) 2.4 GHz T shape antenna
Step 1: What Is NanoTank?
The first time I see NanoTank is at @ushineko3n Twitter. The NanoTank main idea is using the motor case as the axis, this allow the tank become much smaller in size. This project reuse the NanoTank design to build this tiny toy.
Ref.:
Step 2: 3D Print
Please download and 3D print the models at Thingiverse:
https://www.thingiverse.com/thing:5994079
Number of prints required:
motor wheel x2
lower wheel x4
motor gear x2
body x1
side x2
Step 3: Software Preparation
Arduino IDE
Download and install Arduino IDE latest 1.x version if not yet:
https://www.arduino.cc/en/software
Arduino-ESP32
Follow installation step to add Arduino-ESP32 support if not yet:
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html
XIAO ESP32S3
Follow Seeed studio Wiki to familiar XIAO ESP32S3:
https://wiki.seeedstudio.com/xiao_esp32s3_getting_started/
ESP Async Web Server Library
Download latest ESPAsyncWebServer libraries: (press "Clone or Download" -> "Download ZIP")
https://github.com/arjenhiemstra/ESPAsyncWebServer
Import libraries in Arduino IDE. (Arduino IDE "Sketch" Menu -> "Include Library" -> "Add .ZIP Library" -> select downloaded ZIP file)
Arduino ESP32 filesystem uploader
Follow the installation steps to install Arduino ESP32 filesystem uploader if you are not yet do it:
https://github.com/lorol/arduino-esp32fs-plugin
FSBrowserPlus
Download the FSBrowserPlus at Github:
https://github.com/moononournation/FSBrowserPlus
FSBrowserPlus was developed in my previous projects, you can see more details at:
https://www.instructables.com/Strider-Camera-Robot-V6/
https://www.instructables.com/Strider-Camera-Robot-V2/
Step 4: Upload Program
- Open the "FSBrowserPlus.ino" at Arduino IDE
- Modify the WiFi and other settings in "FSBrowserPlus.ino" header
- Select (Uncomment) your camera dev board in "camera_pins.h", this project should select CAMERA_MODEL_XIAO_ESP32S3_ROBOT
- Select Board options according to Seeed studio Wiki
- Press "Upload" button to compile and upload program
- Select "ESP32 Sketch Data Upload" in "Tools" menu
- Select FS Type to "LittleFS" and press "OK" button
Step 5: Soldering Work
Please find the full soldering work video at bilibili:
https://www.bilibili.com/video/BV1x24y1H79h
The GPIO assignment had been revised many times, here are the final connection summary:
XIAO ESP32S3 DRV8833 Drive Board Other Parts
D0 (GPIO1) -> IN1
D1 (GPIO2) -> IN2
D3 (GPIO4) -> IN3
D4 (GPIO5) -> IN4
BAT- -> GND -> Lipo -ve
BAT+ -> Lipo +ve
3V3 -> VCC
OUT1, OUT2 -> Motor 1
OUT3, OUT4 -> Motor 2
Step 6: Assembly
Please see full assembly video at bilibili:
Step 7: Fix Antenna
The antenna is floating in the air, it is better fix it at the middle with a little hot glue:
Step 8: Enjoy!
It's time to show off your NanoTank!
You can see more "making of" video at bilibili:
https://www.bilibili.com/video/BV1Ns4y1h7wp/
https://www.bilibili.com/video/BV1884y1H7TS/
https://www.bilibili.com/video/BV1pb411d7pi/
https://www.bilibili.com/video/BV1Lb411d7xm/
https://www.bilibili.com/video/BV13A411173W/
Step 9: What's Next?
Wish list:
- Power Switch? This NanoTank is too small and not yet have a power switch
- Mission Launcher?
- Speed?
- More Terrain Adaptation?
- Auto Focus?
- Snap Photo? XIAO ESP32S3 Sense have built-in SD card slot
- Sound Streaming? XIAO ESP32S3 Sense actually have built-in digital microphone
- Visual AI?
- Speech Command Recognition?
