Introduction: Camera Slider With Object Tracking
Hello everyone I made this camera slider it has so many amazing features, for example it can slide and rotate the camera in the same time it can stand in 90 degree + 30 degree the electronic so simple don't need arduino or any coding
for this project you need this things :
Hardware parts:
- wiper windshield DC motor
- -12v power supply
- dpdt switch
- two limit switch
- motor speed controller
- -three linear shafts (one of them 56 cm and two of them 60 cm) all of them 12mm diameter
- -5 linear bearings for 12 mm shaft
- -two big ball bearing ( inner diameter is 17 mm and outer diameter is 40 mm)
- -one small ball bearing ( inner diameter is 8mm and outer diameter is 22 mm)
- -six 13mm head size bolt (55 mm length)
- -four 8.5mm head size bolt (52 mm length)
- -one 8.5mm head size bolt (78 mm length)
- -150cm of 6mm belt
- -1kg of PLA filament
Step 1: Design
I designed all parts by fusion 360 and i attached all cad file you can download them
Note/
print part 11 two times
print part 10 six times
Step 2: Electronics
you can use this diagram to wire all electronics
Step 3: Assembly Components
you can see the tutorial for assembling Components
