Introduction: Camera Tazer
I have seen many camera tazers, but none on this website that are illustrated all the way step-by-step.All you need is an old disposable camera, prefferreably Kodak. All brands work, but all are different. I found kodak the easiest type to make a tazer out of.
So, i am posting mine. It comes from a Kodak Powerflash, and can give 380 volts. i hope you enjoy
Step 1: Opening the Camera
first, peel of the stickers to reveil the tab things you are supposed pop open.
using a flathead screwdriver, pop open the tabs.
Step 2: Reorganization
follow the notes, it's easier that way.
Step 3: Chip Chipping
though you are not "chipping the chip" you are going to modify it.
sorry for blurry pictures.
Step 4: Real Modification
in this step, you are actually going to modify it.
this process takes patience.
Step 5: Re-installation
put the middle into the front, and the middle/front into the back. cut off the side tabs to put on and remove the back easier.
Step 6: Finished!
now you need to put the battery back in. after use,TAKE IT OUT.
to use, install battery, click flash, and touch the wires.
DON NOT TOUCH ANYONE WITH THIS!!!!!! 380 volts really hurts, trust me. Hopefully yours will not kill because they are low in amps
