Introduction: Camera for Skiing
About: Hello - I am the scientist formerly known as Naegeli and of course I was inspired by the artist formerly known as Prince. But in contrast to his royal badness I do not want be become the king of pop but the ki…
More specifically, this project is about modifying a ski pole as a camera mount for a 360 degree camera. You can make incredible dynamic footage while skiing with this setup.
Step 1: Drill Hole in Ski Pole
In the basement I found an old ski pole which can be modified to accommodate a selfie stick. The ski pole should be chosen so that the diameter of the pole is a little bit bigger than your selfie stick. Then you only need to loosen the screw to remove the leather strap. Drill a hole in the plastic handle of the ski pole and remove the residues.
Step 2: Glue Selfie Stick Into Ski Pole
Remove the plastic that surrounds the selfie stick. With cotton swaps I smeared two-component glue in the ski pole. Carefully enter the selfie stick into the ski pole.
Step 3: Attach Camera
Reattach the leather strap with cord to the handle of the ski pole. Screw the camera to the selfie stick and now you are ready for your ski adventure using the invisible selfie stick function.
