Camo in a Can
Intro: Camo in a Can
If you're a hunter or just a red neck, camoflauge something in your ilfe is must.
This is my husband's manly anniversary present, or "Man-iversary" present, as he likes to call it.
You will need a weekend and some elbow grease for starters.
STEP 1: Gather Your Supplies
You will need:
-A vehicle or anything in need of a new paint job
-Wet Dry Sandpaper
-Tack Cloth
-Masking Tape / Old Newspaper
-Flat Black Paint
-Camo Dark Brown Paint
-Camo Green Paint
-Camo Tan Paint
-Clear Coat
-Wet Dry Sandpaper
-Tack Cloth
-Flat Black Paint
-Camo Green Paint
-Camo Tan Paint
-Clear Coat
STEP 2: Sand
Sand with Wet Dry sandpaper. You will need the sand the surface of your metal well. I mean really well. Sand until you get that old paint off.
Rinse well, then wipe down with your cloth. You will want to be able to run your fingers over the dry metal and have no residue.
Spray a bit of flat black in one spot, let dry and try to scratch it off. If it scratches off easily you should sand more!
STEP 3: Paint Flat Black
Once your sanding is done, mask off all windows, lights, anything you don't want painted. You can customize this part. I've seen everything but the windows camo'ed and I've seen just trim and accent pieces camo'ed. That's up to you.
Paint everything not masked flat black.
STEP 4: Layers
To make your camo leaves, you need to pick out a good variety of leaves in your yard. Flat ones work best.
Start with your Dark Brown paint. Hold a leave against the surface of the metal and spray over it. Lift up and you will leave a negitive of your leaf on the metal with a dark brown spray surrounding it. Do this to the whole object you're painting. Then repeat with green, and finally tan.
Also use twigs, sticks, the more variety of plant life, the better.
STEP 5: Clear Coat
Clear coat and let dry then peel off your masked areas.
(-This idea was not mine, I found it on youtube, but the technique I kind of made my own).
Enjoy your new camo'ed toy!
10 Comments
Gossimier 4 years ago
Adithyaa Designs 11 years ago
just kidding, the camo is Awesomesauce!
bagnitsch 11 years ago
breumer 11 years ago
black hole 11 years ago
Redneckrebel 11 years ago
You can blend in in the country
You can stand out in the fashion world
Be invisible to a white tail, irresistible to a redneck girl
Camouflage, camouflage
Oh you're my favorite color camouflage
Well the stars and bars offend some folks and I guess I see why
Nowadays there's still a way to show your southern pride
The only thing as patriotic is the old red white and blue
Is green and gray and black and brown and tan all over too
Designed by Mother Nature and by God
It's camouflage, camouflage
(Brad Paisley)
omnibot 11 years ago
thematthatter 11 years ago
l8nite 11 years ago
