Introduction: Camping Hot Tub
Sitting around the camp fire at a lake has left us too hot on one side and freezing on the other.
Drunken idea - A hot tub would keep us warm all over.
It would also get the girls in thier bikinis!
How will a 10x10x2ft body of water be heated and kept hot?
Don't forget to comment, rate and share! :D
Caution!
This intsructable is how to build a Camping Hot Tub and is for entertainment purposes only.
Safetey first!!! It involves power tools, fire, electricity and water. Recreation can be very dangerous.
I am in no way liable for anything you do, damage to vehicles or equipment,
loss of life, accidents that may occur, fines incurred, acts of god, etc.
Leave it the way or better than you found it! Clean-up and don't start a forest fire!
DO NOT CUT DOWN TREES!
Goals:
Transportable hot-tub equipment.
Tools:
Chainsaw
Shovel
car/truck or Generator
Materials:
Tarp 20x20
copper coil 5/8" OD. (outside diameter) @ 100 ft.
hose 5/8" ID. (inside diameter)
hose clamps, Get more than you need!
Washers
Power Inverter
pump 1/12 hp utility continuous operation
Large pond pump
large hose
Rocks (should be on the beach or in the river)
strong metal baskets (look around at thrift stores)
Step 1: Location
Find a really awesome camping spot. Either near a lake or river preferrably within 100 ft or less. Send the minions out to gather wood for the fire. The more the better. We burn a utility trailer load every 3 hours.
The tub needs to be close so it can be filled and refilled as needed.
Step 2: Frame
Find some beach logs and send the minions out to gather wood for the fire.
Caution! Chainsaws are not toys!
Cut the logs to equal lengths so they can be stacked, notching the ends.
Flaten an area so the logs will not roll out of place.
This will begin to look like a log house "foundation",
if there are other groups around - prepare to answer questions.
This frame will need to be about 2- 3 ft tall.
Get a helper to build a fire. Get another helper to move those neatly cut logs with you.
Tip! placing a path of lighter logs on the ground makes rolling the big logs easy!
Step 3: Liner
Place the center of the tarp in the middle of the frame.
The water will spread the tarp to the outside and fill the holes.
Tip! Place a decent sized rock in the middle to hold it in place while filling!
Step 4: Pump Setup
To fill this large hot tub, connect the Large pond pump to the large hose and power inverter or generator .
Caution! If the power inverter is connected to a vehicle and it is the only one there this is a bad idea!
Place the large pump in the water with a filter or it could and will suck up sand. If this happens the pump will break.
Fill the pool with water.
Tip! Use the smallest vehicle as it will be the easiest to jump and restart.
Step 5: Stone Boiling
Caution! Rocks that are hot will burn!
Place rocks in baskets in the fire the minions have prepared. After about 15 minutes the rocks should be hot enough to heat some water.
Caution! Do not place the baskets on the tarp, it will melt!
Use an insulator like large branches to keep the baskets off the tarp. Once there is a signifigant amount of water in the pool,
place the baskets in the water.
Exchange them in intervals of about 15 minutes. 4 baskets of rocks keeps everything moving ahead.
Step 6: The Small Pump
Now the pool is full and getting warm from the stone boiling. Disconnect the power inverter or generator from the large pond pump.
Prime the inlet hose by placing it in the pool. Connect it to the appropriate side of the pump and test to ensure it will pump water.
Connect another hose to the first 50' copper coil with a hose clamp so that there is the proper connection for the pump on the other end.
connect the two copper coils with a section of hose and two hose clamps. Then connect the second copper coil to another section of hose that
leads to the pool. Weight the out-to-pump end of the hose in the pool so it always is free of obstruction.
Caution! The copper coil will melt if water does not flow through it whilst in the fire.
Prime the hose that goes to the pump, turn it on and connect it to the hose that goes to the copper coil.
Things should be wet but functional. Check the in-to-pool end of the hose to make sure water is flowing freely. Troubleshoot if not.
carefully place the copper coil in the fire ensuring ALL rubber connections are at least 1 ft. from any heat, preferrably protected.
Step 7: DONE~!
Things should be warm by now, so go get in and keep the fire and the pump going! Maybe make a new friend! Enjoy the warm water of labour.
This was my first instructable. I hope it was buildable! XD
