Candied Orange Peel
Intro: Candied Orange Peel
In this Instructable, I will show you how to make candied orange peel or citrus peel. This easy candied citrus peel recipe is awesome and it's a great way to use those leftover peels that you most likely just throw away. Don't throw away the citrus peels, make candy with them! If I can do it, you can do it. Let's get started!
Don't forget to follow me and check out my other Instructables. :)
Follow the easy steps below or watch the video tutorial or do both!
STEP 1: Ingredients and Tools
Ingredients:
- 3 medium oranges (or whatever citrus you want to use)
- 3 cups of water (710ml) (for boiling) done 2 or 3 times until bitterness is gone. (6 to 9 cups in total or 1420 to 2130ml)
- 1 cup white granulated sugar (may add up to 2 cups of sugar) (200 to 400g)
- 1 cup of water for simple syrup (247ml)
- Sugar for rolling the peels in
Tools:
- Pot
- Spoon
- Collander
- Knife or peeler
- Wire rack
- Parchment paper
- Sheet pan
STEP 2: Wash and Peel
Begin by washing the oranges really well with water. Then peel them use a knife to cut slits, or use a specific citrus peeler. Then cut the peels into long strips roughly 1/8th of an inch wide to 1/4th inch. It doesn't have to be exact.
STEP 3: Boil, Strain, Repeat
Now add the orange peels to a 3 quart or larger pot. Then add in 3 cups of water. Set the heat on the burner to high and bring the water to a boil. Boil the peels for about 8 to 10 minutes. Then pour them through a strainer and repeat the process a few more times, until they are no longer bitter tasting. You can even just let them boil a little longer, so you don't have to repeat it as many times. Make sure to blow on it to cool it before tasting it, it will be hot of course.
TIP: If you save the water, it makes a great base for drinks. :)
STEP 4: Candy Them
Now after the peels are no longer bitter. Add the cup of sugar to the pot along with 1 cup of water as well as the peels. Turn the heat down to medium. Time to make a simple syrup, 1 to 1 ratio, sugar to water. Bring the water to a boil to dissolve the sugar. Allow it to boil for about a minute, then turn the heat down to low, and add in the orange peels to the simple syrup.
Bring it to a simmer and allow it to simmer for 45 minutes to 1 hour 15 minutes. What will happen is the syrup will turn the orange peel translucent, and that is how you know it will be done. Stir occasionally, but you don't have to babysit and constantly stir the whole time while it is simmering.
STEP 5: Dry, Roll, Eat
Remove the candied peel from the pot with a slotted spoon or tongs and place them on a wire rack with parchment paper under it, to catch the drippings.
TIP: Don't throw out the remaining orange-flavored simple syrup, it can be used to make yummy drinks.
Allow the candied orange peel to dry for about an hour on the rack. Then you can take them, with clean hands, and roll them in granulated sugar. They should be a bit tacky. Once rolled in sugar, place them back on the wire rack.
TIP: You don't have to roll them in sugar, you can dip them in chocolate, or leave them plain.
Allow them to dry on the rack for 4 to 6 hours, until no longer tacky. Enjoy!
NOTE: Store the candied orange peel in a bag or an airtight container in a cool dry place, like a pantry, and they will last a few weeks up to a month.
You can print the recipe here if you like.
STEP 6: Video Tutorial
Now watch those steps in action with this video tutorial. :)
29 Comments
Handy_Bear 3 years ago
In The Kitchen With Matt 3 years ago
joannaraphaella 3 years ago
FlorinJ 3 years ago
What I do with honey instead of sugar: mix them thoroughly after slicing with enough money to cover every bit of their surface, and then some, in a wide bowl. I then place the bowl in a well ventilated place for a few weeks, covered with a sieve or with some gauze, to keep insects away. I mix maybe once or twice a day - honey will run off in the beginning, until the orange peel dries some and starts to absorb the honey. If the slices start to look dry, I add some more honey.
Provided the orange peel is constantly re-covered in honey, it won't mold - honey is extremely sweet and prevents the formation of mold. During the few weeks they stay in honey the orange peel slices loose water and absorb honey. This way, they keep their tarty, acidic taste better than if cooked, in my opinion - they also stay chewier than if boiled. After they're well soaked in honey, and a tiny little bit dried out, I dip them in molten dark chocolate - quality high cocoa content chocolate, that is. To my taste, honey, cocoa and orange zest combined make a wonderful desert. Being a tiny bit chewier than boiled ones also helps with not gulping up all that you make in one go.
FlorinJ 3 years ago
saleemshafi 3 years ago
slimshadyskip 3 years ago
Thanks.
Major Arcana 3 years ago
BrianEV 3 years ago
jannie.lloyd 3 years ago
Other uses for peel. I grate my citrus fruit then dry it in the dehydrator and store in glass jars. Great for adding to cakes or spinking on breakfast cereal. I also add it to my nettle tea to help improve the flavour.
David R 3 years ago
1583803 3 years ago
