Introduction: Candy Corn Fudge Coated Popcorn Monsters on a Stick!
Halloween popcorn balls became popular in the 1950's as a beloved homemade trick-or-treat snack. For this Instructable, I wanted to go a step farther. I decided to coat marshmallow popcorn balls similar to how they make caramel apples but using fudge as the coating. I drizzled them with chocolate and then decorated them with Halloween sprinkles, putting each on a stick! I added my thoughts and ideas as I was making them and ended up with these wonderfully spooky popcorn monsters on a stick! They are such fun treats to make and to eat. The fudge has a very unusual ingredient in it, special for Halloween......candy corn and lots of it! Since I had leftover candy corn fudge, I decided to form, cut and decorate that too, and I have included that in this Instructable. The monsters and the fudge are incredibly delicious! Here is how to make these tasty Halloween treats!
For the popcorn
3 tablespoons coconut oil
1 stick (1/2 cup) butter plus 2 tablespoons, divided
1/2 cup unpopped popcorn kernels
10 ounces mini marshmallows
1/4 teaspoon salt
1/2 teaspoon vanilla extract
tools
electric pressure cooker with a lid
silicone spatula
12 cup bowl
1/2 sheet silicone baking pan or a 1/2 sheet baking pan covered with parchment paper
8 (1/4-inch wide) craft sticks
Step 1: Melt It
Set the electric pressure cooker to saute using high power.
Add coconut oil and 2 tablespoons butter. Allow to melt completely and start to sizzle.
Step 2: Add Popcorn
Add popcorn kernels to the pot. Stir so that all of the kernels are spread out and coated with buttery oil. Place the lid on top. Popcorn will begin popping in about 2 to 3 minutes. Turn the power off when 2/3 of kernels have popped. They will continue to pop but not burn.
Step 3: Into the Bowl
Remove the lid. Carefully remove the pot from the pressure cooker. Pour the popped popcorn into the large bowl. Be sure not to add any unpopped kernels to the bowl.
Step 4: Wipe It Out
Wipe out the pot and place it back in the pressure cooker. We will now use it to make the creamy marshmallow.
Step 5: Melt It
Set the electric pressure cooker onto the saute setting with low heat. Add the stick of butter to the pot and melt completely.
Step 6: Add Marshmallows
Add the salt and mini marshmallows to the melted butter, stirring often, until the marshmallows are completely melted and the mixture is smooth.
Step 7: Turn It Off
Turn the cooker off and stir in the vanilla extract.
Step 8: Add Popped Popcorn
Carefully take the pot out of the cooker. Pour the popcorn onto the marshmallow mixture. Using the silicone spatula, fold in the popcorn until all the popcorn is evenly coated with marshmallow. Allow the mixture to cool slightly.
Step 9: Form Them
Form the popcorn into mounds about the size of a tennis ball using a 1 cup measure. Push a craft stick into the center of the coated popcorn. Carefully scoop out the coated popcorn with the stick from the cup using slightly dampened fingers. Place each mound on the silicone baking sheet. Give each one a little squeeze to remove any air space. Set aside while making the fudge.
Step 10: Rinse It
Rinse any marshmallow mixture from the pressure cooker pot and from the spatula to reuse.
Step 11: Fudge Supplies
3 cups candy corn
1 cup creamy peanut butter
2 cups white chocolate chips
14-ounce can sweetened condensed milk
4 drops red food coloring
8 drops yellow food coloring
small spatula
Halloween sprinkles
5-inch by 10-inch silicone baking tray or a similar size baking pan
toaster oven size baking sheet
Step 12: Cook It
Add the candy corn, peanut butter, white chips and condensed milk to the pressure cooker pot on the saute setting using low heat. Cook and stir until the mixture is smooth. Turn off the heat.
Step 13: Add Colors
Stir in 4 drops of red food coloring and 8 drops of yellow food coloring to intensify the orange color of the fudge.
Step 14: Coat Them!
Use the small spatula to pick up a popcorn mound from the baking sheet. Holding the stick, quickly spoon hot candy corn fudge over the popcorn, allowing excess to drip off. Sprinkle with some Halloween sprinkles. Set it back on the silicone baking sheet. Repeat, coating each popcorn mound with the fudge. Set aside or refrigerate while doing the next step.
Step 15: Form the Fudge
I like the bonus of having leftover fudge. It tastes amazing and will make great little treats for family and friends. Using the silicone spatula, pour the remaining fudge into the silicone baking tray. Set it on the small metal baking tray for stability. Any similar size small baking pan will do. If the pan is not silicone, line your pan with wax paper or parchment paper so the fudge doesn't stick. Sprinkle with some Halloween sprinkles over top. Refrigerate the fudge until firm or over night.
Step 16: Remaining Supplies
Cutting board
French fry cutter (or sharp knife)
1/2 cup semi-sweet chocolate chips
small scissors
reclosable plastic sandwich bag
microwaveable small bowl
spoon
Step 17: Cut It!
Remove the block of fudge from the baking tray and place on a cutting board. Use the French fry cutter to cut the fudge in each direction, forming one-inch wavy-edged squares.
Step 18: Melt the Chocolate
Place the chocolate chips in the small microwaveable bowl. Microwave at 70% power for 40 seconds. Stir with a spoon. Microwave again at 70% power for 40 seconds. Stir well. Continue microwaving at 30 second intervals, if necessary, until the chocolate stirs smooth.
Step 19: Bag It and Snip
Quickly spoon the melted chocolate into the resealable bag and seal. Using the scissors, snip a tiny corner from the bag.
Step 20: Drizzle It!
Drizzle the chocolate over the coated popcorn mounds and the fudge. Sprinkle the chocolate with more Halloween sprinkles.
Step 21: Eyeballs!
I remembered I had some candy eyeballs in my stash of assorted sprinkles. I then decided to make monsters out of my mounds of coated popcorn, adding 2 eyes to the front of each mound. I thought they were the perfect addition to make them cute for Halloween!
Step 22: They Are Finished!
Here are some of the finished Candy Corn Fudge Coated Popcorn Monsters On A Stick! I am excited to share them and the fudge too!
Step 23: Wrap Them
If desired, you can cut plastic wrap to cover and wrap each monster and each piece of fudge! You can keep them in your freezer until you are ready to share them........or if you would like to sneak some for yourself! I already bought some more candy corn because I think these will all be gone before Halloween and I will make the monsters and fudge again! They really do taste amazing! I hope you give this recipe a try! Everyone will smile and enjoy them!
