Introduction: Candy Drop Dispenser!
Welcome! This is a candy drop so if you were to press the button then candy will drop from the SKY! It can also be used for Halloween. You could move a statue or something(be creative) so that when you move it it will press the switch! This project should only take 30 mins. All you will need is: Arduino UNO, servo motor, four screws, two pieces of thin wood, resistor, button (or something like it), tape, big rounded juice container, wires and if you would like, a breadboard. I will be using a breadboard in this project.
Step 1: Building the Dispenser
follow the instructions on the pictures.
Step 2: Building the Circuit.
Step 3: PROGRAMING
This is a simplified version of the basic function that when the button is pressed it drops candy. It works, go ahead and try it.
Step 4: Now Just Hang It Up Somewhere!
Use you imagination for changing the button to something else use a riddle to find the secret statue that they must move that will press the button! Have fun!
Look at some of my other projects at https://www.instructables.com/id/Candy-Drop-dispenser/
https://www.instructables.com/id/Password-protected-Secret-Telling-Arduino/
https://www.instructables.com/id/Arduinik-The-HumanoidBiped-Robot/
https://www.instructables.com/id/RFID-Reader-Identify-anything-with-RFID-from-cred/
