Candy Sprinkle Cake Stand
Intro: Candy Sprinkle Cake Stand
Prepare yourself for a sugar rush. I'm going to mix glue, cake sprinkles and cherry wood into a bonkers looking cake stand.
I don't think I was quite prepared for how colorful this project would end up or how much of a mess it would leave in the shop! Still, I'm quite pleased with it.
My daughter was the only one who protested... "Dad, you used ALL the sprinkles?!"
STEP 1: Casting the Top
The mold for this casting was a discarded piece from a previous project. I clamped it to an HDPE cutting board that I first lined with packing tape. If you don't have a round mold, and copious amounts of packing tape, you would just cast this in a shallow square pan. The major disadvantage of that is having to mix extra epoxy.
Many hobby stores sell inexpensive casting molds and I would recommend them as a good investment.
The epoxy I used was the type sold for bar top counters. It wasn't really designed for this application, but it appears to have worked well. (thus far). It was $25 at the Home Depot. I then added a full jar of sprinkles, lightly heated the mix with a heat gun ( to draw out the bubbles) and let it sit for 24 hours.
STEP 2: Lathe Work
The casting came out great! All the sprinkles settled at the bottom (now the top) and it was super colorful!
but....
It had a jagged edge that needed cleaning up. I was really worried that the epoxy would be brittle and break off in chunks at the lathe. Not the case. It came off in long wisps and spread all over the shop like epoxy cob-webs. A very cool but messy effect!
Next I turned a small piece of cherry for the base. Nothing fancy, just to raise the plate up a couple inches off the table. When I made it, I thought it had a mid-century modern look to it. Of course in the final project it is barely even visible, so I'm not sure it's terribly important. The sprinkles steal the show...
STEP 3: Completed
Besides the casting, this is a fairly simple project. Cast the top, turn the base and glue them together. The most harrowing part was turning the edge of the resin.
If you didn't have to wait 24 hours for the glue the totally time invested here is only a couple of hours. And the joy of epoxy is you can cast ANYTHING you want. Glitter, legos, M&Ms.... Go nuts.
I know I have...
4 Comments
HeleneJ 8 years ago
What about using resin instead of epoxy?
LindsayJ5 8 years ago
Beautiful and great idea! Do you see these completed?
tomatoskins 9 years ago
The sprinkles look great! Is there any danger in turning an piece of epoxy on a lathe like that? or is it generally strong enough to hold together?
kludge77 9 years ago
Epoxy can be brittle, and bits can fly off but it's quite solid! No more or less dangerous than wood. Always wear your face shield!
