Introduction: Car Headlight Arduino Photoresistor Sensor
Be able to tell whether or not you headlights are on using an arduino and photo sensor
Step 1: What You'll Need
1. Arduino *I used and Arduino Uno
2. Jumper Wires
3. Vehicle with manual head lights
4. Led
5. Photoresistor
Step 2: The Circuitry
A current runs through A0 To the photo resistor which then sends so much current through depending on the amount of light that hits it. It then goes to ground and tell the Arduino whether or not to turn on the light depending on the thresh hold number.
1. Connect the photo resistor to ground and A0
2. connect the led to to ground an digital pin 13
* You may have to adjust the threshold to accommodate you're lights.
The code
int lightPin = 0; //define a pin for Photo resistor
int threshold = 17;
void setup(){
Serial.begin(9600); //Begin serial communication
pinMode(13, OUTPUT);
pinMode(A0, INPUT_PULLUP);
void loop(){
Serial.println(analogRead(lightPin));
if(analogRead(lightPin) > threshold ){
digitalWrite(13, LOW);
Serial.println("LOW");
}else{
digitalWrite(13, HIGH);
Serial.println("high");
delay(100);
Step 3: Finish
Test your photo sensor using the serial monitor to get a sense of what your thresh hold needs to be. Now enjoy being able to sense light and have an led turn on.
