Introduction: Car Stereo to Home Stereo With a PSU
I'm going to show you how to run a car stereo using an old PC power supply. If you're bored and want a project, or you're like me and just like making things instead of going out and buying purpose built ones, this is for you.
If you manage to screw up your stereo, speakers, power supply or anything else, don't blame me.
Also, this is my first Instructable, so it was kind of a learning curve on how this website works.
Step 1: What You Need
You'll need:
Car stereo- I'm using a Sony Xplod CDX-R3000
Speakers- I have a set of Acoustic Research and a set of RCA speakers
PSU- old computer power supply
Wire strippers
Wires
Speaker wire
Electrical tape
Step 2: Wire Your PSU
To start, find the large connector on your PSU.
Now, find the green and black wires right next to each other. Put a piece of wire between these as a jumper. This will make the PSU power up when you turn the switch on.
Step 3: Wiring Your Stereo
To begin with, get the red, yellow and black on the stereo
Red is ignition, yellow is constant and black is ground.
Twist the red and yellow wires together. This is to make the stereo power up.
Step 4: Stereo and PSU Meet at Last
This is where the stereo and power supply meet at last
Find one of the four pin connectors, with the yellow, black and red wires on it
You need a yellow and black wire next to each other
The black ground on your stereo goes to the black wire on the connector
The red and yellow on the stereo go to the yellow wire on the connector
Step 5: Wire Speakers
This is about as simple as it gets. Almost all car stereos follow the same wiring diagram. Just hook your speakers up the same way.
You can solder all the wires for a permanent installation, but I'm constantly changing what I have so I just twist and tape.
You won't need the blue antenna wire, brown (if yours has one for muting), blue with white line unless you add an amp and sub, light green (parking brake) if you have one, or orange (illumination) as most aftermarket stereos don't have an illumination wire.
Gray and white are front speakers, green and purple are rear speakers. Negative has a black strip on it, positive is a solid color.
Step 6: Plug It In, Power It Up
The time has come to test it.
Plug the cord in, and hit the switch, and hope it works.
If you did everything right, it should work fine.
Step 7: You're Done!
This is the finished product set up in my bedroom.
You turn it on and off with the switch on the PSU.
Don't bother setting the clock or anything, because it loses its memory every time you shut it off
27 Comments
1 year ago
I tried to connect my power supply to the car stereo but the fan spins once and doesn't do anything else, won't even power my stereo
1 year ago on Introduction
I have a suggestion. Instead of a PC power supply, I used a car jump starter (kind of like this: https://www.ebay.com/itm/Schumacher-Portable-Power-Jump-Starter-Car-Vehicle-1000-Amps-SL1397-New/183780894113?epid=3026177682&hash=item2aca31e5a1:g:gTcAAOSwflBcuie~) to power my car stereo. It has a built in battery so you'll get constant voltage, and the jumper terminals are switched which works as your ignition power source. Inside my jump starter, the wires are all bolted together so no soldering was required. I just ran the three wires (ground (-), switched +12v, and constant +12v) through a hole I drilled in the case. I connected the three wires to a Molex connector so I can unplug the jump starter should I need it to start a car.
Question 2 years ago
I am using JVC kdr414... When I turned on the power, 'PROTECT' started blinking on the display. What should I do?
3 years ago
Big thanks! This was really mind blowing when I found out the possibility of hooking up car audio quality sound in the house.
Although it is optional, you have to take into consideration that most modern car stereo units (I'll just call them CSU's) have a heatsink. These heatsinks can warm up as quickly as a desktop CPU. After I put mine together, I took a 120mm Cooler Master SickleFlow cooling fan and placed it behind my CSU. After that, the CSU itself never heated up at all. I played music for 3 hours and it still never heated up.
So in short, it is best to have a cooling fan in handy - and make sure the fan itself also runs on 12V of DC power! I did post a snapshot of my setup, hope it helps!
~quad8
4 years ago
thats pretty neato, this actually is a good method i was looking at doing something similar with a desk PC I am building, and what a great way to use up the old molex cable, when I do it the 24pin connector will be plugged into the motherboard, so essentially when you hit the power button to fire up the PC stereo will turn on and what not
Reply 4 years ago
connect it to PC aux or blue tooth no problem be able to sync up the lights on the PC to the tunes, great inspiration
Tip 4 years ago
I'm a natural tweeker so I know what your going through, I built my own entertainment center out of my damaged bed, hell I love it.
5 years ago
Can you directly wire this to your house maybe I have a crappy mobile home with an even crappier wired in radio with speakers throughout the house the radio stopped working last month this would save me alot of money
5 years ago
Thanks for the detailed instructions! I made one for my home over the weekend. Had a PSU lying inside a PC cabinet I hadn't used in years. And a brand new car stereo I'd bought on clearance about 6 years ago and never used (since the new car I bought around the same time came with a decent factory-installed stereo).
In my over-enthusiasm in clearing up the jungle of wires from the PSU, I ended up cutting off all the yellow and black wires as well - close to the PCB. Nothing to do but buy a new PSU. All the computer hardware stores around were selling overpriced crap PSUs. Thankfully, Amazon came to the rescue with a next day delivery of a new PSU.
Now, my bedroom stereo has a CD player, twin USBs, Bluetooth, and Chromecast audio! All that remains now is an FM antenna, and I'll be set. Maybe even hook up my bedroom TV to the speakers, using a stereo mixer (Altoids to the rescue!)
5 years ago
PSU output its 240v.. how do i make it ? can i just follow your step ?
6 years ago
I have a car stereo but I have lost the back side socket plug of 12 pins. So now, What should I do ?? I think posting some images might help u great people to help me... :-)
Reply 6 years ago
If it's any name brand stereo like Pioneer, Sony, JVC, etc you should be able to just order a new plug for it online. Search the model number of the radio and you should be able to find one
Reply 6 years ago
Also check Crutchfield. They have wiring harnesses for almost every make and model.
Reply 6 years ago
There is a conflict between my pc monitor and car stereo(connected through AUX to PC) ...... I can explain the problem if u r willing to help......
Note.: monitor is connected through VGA(analogue).... I guess it may b the reason.... Any help is appreciated.. :-)
6 years ago
If you have a detachable face unit, you can just turn the unit off by detaching the face and your settings (station pre-sets, clock) should remain intact. You can keep the PSU on.
Over 30 years ago, I hooked up the radio (AM/FM analog stereo radio only) from my Mom's '77 Ford Granada to a 12 volt supple and the only problem I had was that the light stayed on after I turned the radio off. I had to unplug the 12 volt supply to turn the light off,
Also...shouldn't you have an antenna attached to the unit? I did for mine.
6 years ago
thanx. looks what i need. may be with lasercut box will be nice home stereo.
6 years ago
Hey what happens if your PSU that I took out of a gateway with windows ME does not have a power switch? I think I have everything hook up just the way you said, but the PSU doesn't have a on switch. Any thoughts?
Reply 6 years ago
It shouldn't matter what the PSU came out, they should all work, and they don't need to have a switch to work. On the biggest connector on the PSU, did you jump the dark green wire to a ground? This is how you trick the PSU into powering up
7 years ago on Introduction
89JeepComanche
I had some old car stereo components in my garage this morning and wanted to complete this very same project. I also had an old working PC power supply, so your post is very appealing. This is a great idea, and I'm sure this could work very well.
I may still try to use your idea of the PC power supply. Or, I may go purchase a relatively cheap automotive AC/DC power inverter for the task.
I want my installation to be permanently mounted, and above all, SAFE, when I am completed. The only way I can ensure this is to check my work with a cheap multimeter, available from most large hardware stores for <$20.
Your vehicle's electrical distribution system is a regulated 12VDC system. This should be supplied to your stereo in parallel across the black wire and red/yellow twisted pair.
The power supply may or may not be capable of the amperage output your stereo will draw. The power supply itself may have a sticker to notify you of the maximum amperage draw. The stereo will most likely have a similar sticker, letting you know the maximum expected amperage draw. In reality, the amperage draw will depend on the speakers used and the listening level. The amperage can be tested by breaking the line between the stereo and amp on either side (but some cheap multimeters will only allow you to read a positive amperage).
In addition, your car electrical system is fused to protect from an overcurrent condition from damaging electrical components and starting a fire. Adding a simple, cheap fuse harness with a fuse rated for your stereo can help prevent a disastrous outcome.
Overall, great idea! I must admit, I have never performed this task myself. I woke up this morning and wanted to try it and your post was the first I found. My goal is only to be helpful and enhance.
Take care, and good luck.
I never bothered to check amperages and I never bothered with a fuse on mine, especially because there's a 10amp fuse in the back of car stereos, but the power supply has been on and the radio in standby when it's not being used since I made this Instructable. I've never once turned it off, except to change the stereo to one with an AUX and USB and clean up the wiring, and it's never gotten hot or given me a problem once. I had similar concerns at first too, so I kept an eye on it the first couple days it was hooked up, but it never popped a fuse or overheated, so I just let it be and it's never done anything since. You can always use an inverter if you want, but I used a PSU simply because I had three of them lying around. Thanks for the comment, and good luck with yours.
