Introduction: Carboard Ukulele Stand
This Instructable will show you how to make a Cardboard Ukulele Stand in order to show off your Ukulele. It can be used with pretty much any Ukulele with a standard body shape, but was originally designed to go with a Cardboard Ukulele. This project is really quick... not including glue drying time, it should only take about 20 minutes.
Step 1: Supplies...
Supplies:
Corrugated Cardboard
Glue (I don't recommend super glue, but wood glue, paper glue, epoxy will all work)
Tools:
Sharp blade
Tools:
Sharp blade
Step 2: Measure Uke....
Measure the depth of the body of the ukulele that you are making the stand for. Multiply this number by 1.5. This will be the width of the notch in the stand. In the figure below, I am measuring the depth of my uke to be 2 3/8 inches. The notch in my stand should be 3 9/16 inches.
Step 3: Template....
Attached is a word document that has the template for the stand pieces. I will attach a PDF of this template when I have a chance to convert it at work.
*** Update 2/18/13 - Apparently, instructables doesn't like *.doc files anymore! I've attached the template with a TXT file extension. Download it as a TXT and change the file extension to .DOC before trying to open. Now that I know this is a problem I will really try to convert the file to a PDF. Sorry for the inconvenience! ***
Scale the template so that the width of the notch measures the number you calculated in the previous step. For me, that was 3 9/16 inches.
Print out the template and reinforce it with some thin cardboard. Cut out the template using a sharp blade.
Step 4: Trace and Cutout...
Trace the template onto your corrugated cardboard. You'll need a total of 6 pieces. I like to mix up the orientations to make sure that is has strength in all directions.
Cutout all of the pieces using a sharp blade.
Step 5: Measure Thickness...
Stack 3 of the pieces and measure the thickness of the stack. In the picture, the thickness of my stack of cardboard is 5/16 inch.
Step 6: Measure Slot...
On the template, there is a line marked "Cut Centerline". Transfer this line to each of your pieces. This is the centerline of the slot that you will cut. After drawing the line, measure half the thickness that you determined in the previous step on either side of the line, so that you will wind up with a slot the same thickness as you stack of cardboard.
Step 7: Cut Slots...
Three of your pieces will have a slot that goes from the top of the stand halfway down and the other three will have slot that goes from the bottom of the stand halfway up. I've marked the midpoint of the centerline on the template you can use to scale.
Cut the slots with a sharp blade.
Step 8: Test Fit...
Test fit the pieces together. If they don't fit, trim the slots as needed until they do.
Step 9: Glue...
Glue the pieces together so that you wind up with two stacks of three pieces.
Weigh down your stacks with a heavy book.
Step 10: Assemble Stand
Once the glue has set, assemble the stand. And you are done.
