Introduction: Card Holder
Card Holder that is cut out of wood by the Laser Cutter
Step 1: Design and Model Thinking
Dig deeper into your thoughts to discover what you want to make?
Step 2: Download
Download SketchUp & 123D Make the applications
Step 3: Create
Design a model in SketchUp
Step 4: .stl
Export the model file from .skp to .stl
Step 5: Import
Import the .stl file into 123D Make and convert it to stacked slices.
Step 6: Export 2
Export the .stl file from 123D Make as a .dxf file and view it in Adobe Illustrator.
Step 7: Cut
Copy the .dxf file onto a thumb drive and upload onto Adobe Illustrator on the computer linked to the laser cutter, then delete all the leftover files from the person before you (if there was one). Then download your file and run the machine.
Step 8: Assembly
Remove the pieces from the laser cutter and use a hot glue gun to stick all of them together in the correct order.
