Introduction: Cardboard Boat
This boat is helpful to people and we can use it for rescue and this is the main material is cardboard. This boat only use household object and you can make this easily
This is my material
-5 Cardboard
-12 Pet bottle
-1 Ruler
-2 Packing tape
-4 Toilet roll
-1 Scissors
-1 Glue (just in case)
Step 1: Cutting the Cardboard
Make a line to be cut the cardboard and the length is 50cm and the width is 1m.
This cardboard used to be the right side left side, and hull side and the front side is a different size to be made.
This step makes the boat to be cardboard so first is cut to be the left side, right side.
Step 2: Taping for Side and Front and Back Side.
Tape the front and left side and right side and backside with duct tape. (tape up will)
The card has a length of 50cm, a width of 1m, and the backside is has a length of 50cm, the width of 1m.
Use tape to attach the right side, left side, and front of the cardboard, but apply the tape vertically so that it doesn't peel off.
Step 3: Attach to Be the Pet Bottle
Tape 4 pet bottles together, then tape to the left side of the boat horizontally. Repeat on the right side and hull side.
Taping to be pet bottle in 3 times taping for pet bottles.
Step 4: Attach to Be Big Card Board Tubes
Big cardboard tubes to support the bottom of the boat (the cardboard ones)
The length of the big cardboard tubes is 60cm and the width is 10cm.
Put a tube on the hull side, post it horizontally instead of vertically.
Step 5: Put in the Big Bag
Put another piece of cardboard inside the cardboard (the same size to be cardboard)
Then we put duct tape on it put a big bag (thin, wet hateful bag) around the cardboard.
Step 6: Make a Oar
Make an oar use cardboard and cut to shape in the photo.
Length is 50cm and width is 60cm.
Step 7: Taping to Toilet Roll
You need 4 toilet rolls and attach them with tape to make the handle.
The length of the toilet roll is 15cm and the width is 5cm.
