Introduction: Cardboard Camera and Paper Flowers
Cardboard camera with a bouquet of paper flowers, made from book pages wrapped in purple construction paper. Can be used for decoration or a fun craft. Prior art doesnt have the camera painted, or the flowers wrapped in paper.
- Cardboard
- Paper
- Colored paper
- Hot glue
- Tape
- Spray paint
- Watercolors
Step 1:
Use Rhino to laser cut cardboard
Step 2:
How to assemble:
Combine the 41 by 9cm cardboard rectangle and both 15.5 by 5cm boot looking rectangles to make the base of the camera.
Glue the rectangle without corners sides where the corners would be together to make a little box.
Now glue the little box to the top of the camera base.
Glue one of the 3 larger circles to the front of the camera base where the lense will be.
Glue the 7 by 11cm rectangle with a semicircle jutting out the side to the back of the camera.
Now Glue the 5 by 8.3cm rectangle on top of the previous one leave space around the semi circle.
Glue on of the large small circles to the semi circle.
Glue the 4.2 by 5.5cm rectangle boot on top of the camera to the right of the previosly glued box.
glue the 2.5 by 4.7 rectangle on top of the one you just glued leave room around the semi circle.
Glue both of the smallest circles together then glue to the semi circle on top of the camera.
Using both of the smaller large circles and the 6 by 22cm rectangle create a cylinder.
using both the largest circles and the 7 by 27cm rectangle create another cylinder.
Glue the smaller cylinder to the large circle on the front of the camera.
Now glue the larger cylinder on top of the smaller one.
Optinal: Wrap the 2.5 by 22cm rectangle around the smaller cylender for decoration.
Optinal: Wrap the 2.5 by 26cm rectangle around the larger cylinder for decoration.
Step 3:
Use back spray paint on the camera, then water colors to give the lense a metalic look.
Step 4:
Instructions on making paper flowers are above
