Introduction: Cardboard Dolphin Maquette
In this instructable you will be provided with the steps necessary to create a cardboard maquette of a dolphin. It is important to capture the main aspects and features of a dolphin to make it really come to life. The goal of this instructable is to give clear and easy steps to help you make a maquette by only using cardboard!
- Matte Knife
- Cutting Board
- Cardboard
- Pencil
- Eraser
- Sketchbook
- Access to Internet
Step 1: Sketches & Inspiration
To make an accurate representation of something it is good to look up real images of it to find inspiration. Studying the object is also a good way to start a project.
Drawing sketches is important because it gives you an idea of what you are going to create. You can base your maquette off of your sketches and it is a critical tool to use.
Step 2: Main Body
Use the sketches you drew to draw an outline of a dolphin’s body on the cardboard, then cut it out. You can make as many spines as you desire but there must be at least two.
Step 3: Spinal Structure
Cut out ¾ of an oval wide enough to fit around both spines of the dolphin. Cut as many slits as you have spines in the ovals and put on top of the dolphin to connect them and keep the dolphin stable. Make as many as necessary.
Step 4: Fins & Tale
Cut out the fins and put more slits in the side of the ovals to connect the fins to the body. Cut a slit in the top of the oval to connect the dorsal fin. Place the tale at the end of the body and cut slits to slide the tale in.
Step 5: The End!
Congratulations! You now have made cardboard dolphin maquette yourself. I hoped you enjoyed making this project and hopefully this instructable was useful and helpful.
Now you get to relax and enjoy your own handy work.
